R53 Going from X-Lites to S-Lites...What's Involved?
But if you stay with an OEM sized tire, the overall rolling diameter will be virtually identical between a 16 and 17 inch rim/tire combo.
What you may notice is slightly improved acceleration due to the decrease in unsprung weight, and you will almost definitely notice the ride is improved with the 16's.
on
Stick with X-Lites
So OP do you want to trade your R84 X-Lites at 17.6lb for R85 S-Lites at 25.1?
Besides the 7.5 pounds per corner lighter, you also get tires cheaper for 16s, too, you know? Keep the X-Lites until you save for some nice lightweight 17' wheels that you love from Tire Rack, then keep X-Lites for winters or for track/auto-x events.
Check out NAM Marketplace they got some nice light Motegi TrackLites 14.3lbs too:
https://www.northamericanmotoring.co...ct/6455/cat/46
https://www.northamericanmotoring.co...ct/6509/cat/46
https://www.northamericanmotoring.co...ct/6583/cat/46
https://www.northamericanmotoring.co...ct/6348/cat/46
Yes, assuming I buy this car I'd go from X-Lites to S-Lites. The reason? They just look a whole lot better. Of all the OEM wheels, they look the best to me. Sure, I could go aftermarket but I think my modding days are behind me now. I'm not racing the car so either way I probably wouldn't notice the difference. Also, when the day comes to sell off the car (and I will sell it eventually) it will fetch higher value if it's kept stock. I'm learning that the hard way with my current car.
If it were me I would stay with the x-lites for these reasons:
First is you would be able to keep the good acceleration, braking and ride that lighter weight wheels provide.
Second is with lighter wheels, and non-run flat tires, there's a lessened chance of strut tower mushrooming.
Third is the suspension will be less stressed and react better with the lighter weight wheels.
So if your dead set on the S-lite look you might consider MiniLites or Rota RB's.
Both weight about 18lbs and the MiniLites are hub centric.
And lastly you will feel the difference as those of us the went from heavy to light can attest.
Hope this helps...
Hope this helps...
Sailorlite
09-21-2015 12:00 PM
Mini Koopa
R55 :: Clubman Talk (2008+)
09-08-2015 02:58 PM
I_drive_slow
08-27-2015 08:41 AM
