Hub Ring Sizing?
Anybody know what size hub rings I need for 17" Rota Attacks? One of the rings I had on there has mysteriously vanished!
I know the inner measurement to fit the hub is 56.1, but what about the outer measurement? Should I just pop the wheel off and measure the diamater???
http://18racing.com/wheel_attack.html
Do you have 17x7.5" 4x100 bolt pattern +45mm offset (should have 45 stamped on inside hub center area). Then it is likely your hub bore on the wheel is 67.1mm.
You can confirm this with calipers or email to
Jessica@18racing.com where they sell Rotas.
Then
http://www.1010tires.com/hubrings.asp
Hub Centric Rings (set of 4) - O.D. 67 - I.D. 56.15 HR67-5615 $24.99
Rota does make different sized wheels from time to time so just look on the inside of the wheel hub and usually there are wheel size and offset markings to confirm the specs.
Hey, you are in Santa Clara?
My son is moving in to SCU this weekend for school. Maybe he will see your MINI around. He was driving my MCS to High School this year.
![Thumbs Up](https://www.northamericanmotoring.com/forums/images/smilies/thumb-up.gif)
![Nod](https://www.northamericanmotoring.com/forums/images/smilies/nod.gif)
