New wheel compatibility
11-09-2009, 08:16 AM
on
Hello All - I have a question. I am looking at buying a used set of rims. The owner had a 2008 Mini Cooper. I have a 2009 Mini Cooper Clubman - will the wheels fit? I have read mixed things about wheel changes....any guidance would be appreciated. Thank you
11-09-2009, 08:24 AM
Yah they'll fit. The 08 MC And 09 Clubman are basically the exact same as far as wheel fitment goes.
11-09-2009, 08:41 AM
long as they are 16"+ your fine
11-09-2009, 09:36 AM
on
Also as long as it's an 08 Hardtop and not a convertible.
11-09-2009, 10:08 AM
Quote:
Originally Posted by
trbasil
should still work fine. most all stock wheels are interchangeable, even with the lug differences. an 08 vert is still 14mm just like the coupe
11-14-2009, 12:43 PM
hold on
but look at the OPs sig, he has an S. Wouldnt there be a clearance issue with MC or MCC wheels and the S's larger brakes, even with 16s?
(requested a mod move this thread to the wheels forum.)
11-14-2009, 03:55 PM
on
sequence
but look at the OPs sig, he has an S. Wouldn't there be a clearance issue with MC or MCC wheels and the S's larger brakes, even with 16s?
Yes, there would be a clearance issue.
None of the 15 inch and not all of the 16 inch wheels will fit.
To answer the question, which wheels will work, go here for a handy chart:
http://www.mini2.com/forum/faq.php?f...heel_tire_tech
Hope this helps...
Bruce/Fl
08-28-2015 11:59 AM
08-25-2015 01:39 PM
AdrenaliNate
08-24-2015 12:37 PM
AZN Optics
Accessory Products
08-21-2015 02:03 PM
AZN Optics
08-21-2015 02:02 PM
