225/35/18 td 1.2 18x8 et 45
I was wondering if these would be a good setup... i am not looking for stretch/poke, just a more aggressive look and possibly performance gains?
I have an r56 s and am considering team dynamic pro race 1.2 18x8 et 45, with 225/35/18 tires.
1. I am pretty sure they will not rub on stock suspension. Also, if i were to drop in the future, it would be ok i presume?
2. i figured thicker rubber = more grip but somewhere in this forum, someone stated it will cause more understeer? is that possible?
3. i want to go 18s but the only size tds offer is 18x8... 45mm offset is reasonable yes?
thanks in advance
thanks in advance
thanks in advance
thanks in advance
on
i have this exact setup 18x8 et45 225/35/18 and im all the way down on my h&r rss coilovers, its hella annoying sometimes because it does rub lock to lock, and the ride is really harsh from the 18's, im going with a 16x7.5 so i advise, if you are going to lower your car, do not run 18's...sacrificing quality of the ride, let alone the weight of the wheels/tires, for looks=fail, as i have failed on this setup.
you can see my gallery for how it will look if you lower on 18's.
on
Tire size (35 series) make for a bumpy/jittery ride too.
"possibly performance gains?" Not Likely!
Better performance from what the Stig suggested, or even smaller 17x7.5 and 215/40-17 would be better than heavy 18x8s and 35 series (225/35-18) tires. Mine came stock with 18x7s, but when I need better performance I run 17x8 ET42 w/ 225/40-17 or 15x7.5 w/225/45-15.
my car isnt lowered yet... and if i ever did, i dont plan on going as low fronjoni....
only reason i wanted to get low profile tires was to stay within the stock diameter. 205/45/17 is not soo much different from 225/35/18 in terms of diameter. I guess lower profile means less absorbed which means bumpy ride.
Ill be running on stock sport suspension... maybe ill risk a higher profile...
on
yukinoinu
15
08-24-2015 09:20 AM
