Switching Run Flat Tire
If you are refering to the unmounting of the RF tire then remounting it when spring comes ? The only hazzard will be to the rims.
RF tires are much more difficult to remove and mount. Best to find a shop which regularly deals with RF tires, and from the git-go, tell them if they damage your rims in this process, they will be buying you a new set at about $400.00 each.
Runflats tend to be more expensive and more difficult to change....and most places will tell you it takes a bit longer. I have also been told by tire people that after a tire has been unmounted/remounted more than 3 or 4 times, they can sometimes have trouble getting a good seal between the bead/rim. If it costs you $20 per tire, 2 times a year to mount/rebalance the tires...it might be signafigantly more at some places to do runflats...and the rims may be scratched...it adds up quick!!
For this and the cost reasons, I would strongly suggest you pick up a second set of rims...I bit the bullet and did this...best thing I ever did...that way the salt/sand etc will not destroy your factory rims (if you like them), and they stay looking nice much longer. If you hate the OEM rims, they tend to be strong and heavy...they make great winter rims, so get a nice aftermarket for your summer tires!!
I went with a smaller rim, to improve my winter ride, and I saved $$ on the cost of the winter tires and rims, since smaller rims cost less $$.
07-16-2020 12:54 PM
ltjpunk7
09-06-2015 07:32 AM
