wheel/tire fittment??
If it's on a Gen II, I personally think they'll fit just fine. I run Konig Tractions that are 16x7 et40 with 215/50-16s and there's plently of room. The 10mm difference between your choice and mine equates to .4 inches wider tire stance (or .2 inches on the inside and .2 on the outside), and I can tell you I have enough room inside and out for the extra width. But keep in mind, that's on a stock MCS suspension with no lowering...so there are some points to consider if your setup is different.
Poster #11 may help ya. He has an r53 and I am sure has used diff set up's.
BTW; did you bother to do a search before posting ? There are a few threads already on this stuff.
yep, sure did...couldn't find anything specific to the Foils though. there are a couple of other konig's that i could find evidence that they fit a mini, but nothing on the Foils.
LagunaSol
Tires, Wheels, & Brakes
11-22-2005 04:19 PM
