They are but on OEM wheels, the holes are the same size. So it's possible to use R53 wheels on an R56, if they clear the brakes, etc.
Exactly
The wheels dont care if you use 12 or 14mm bolts. And you'd be hard pressed to find a wheel that CAN fit a 12mm bolt but CANT fit a 14mm bolt (or vise versa)
