215/45/17 with 40mm offset
Yes. Depends on how low, amount of rear negative camber, and wheel width.
I rubbed a little with 17x7" +38mm offset wheels, 215/40x17 tires, H&R springs, and -1.7 camber. Since you plan 45 series that adds a great chance of rubbing. However, the rub should be minor and the plastic wheel well liner and wheel arch can be trimmed to eliminate the rubbing.
Is the load rating on the 215/40/17 Star Spec sufficient for the Mini application? If so, I'm inclined to go that route.
on
I'm on 215/45R17 Dunlop Direzza DZ101's on BBS RZ's (17"x7" ET37), R53 with H&R springs, and I rub in the rear at full compression (hard bumps, etc)
Looks like its just the plastic edge of the rear wheel arch, but it's still chewing up the shoulder/sidewall of the rear tires, so I'm getting the fenders rolled when I put on the CF hood in a week or two.
If I was stock height or on 205's, I'd be fine.
Star specs are on the smaller circumference end of the spectrum in each size from what I've read. I have and R56, and everyone told me that 215/45/17 wouldn't rub on NM Engineering springs. Guess what?
I'd definitely go 215/40. I just placed an order for 16" feathers and 205/50/16 because of the rough ride and rubbing... But like I said, I'm in an R56.
Chibi2
05-19-2016 03:46 PM
vbmike
10-15-2015 04:32 AM
