SSR GT7 NEW!!!!!!
Old 12-23-2003, 02:49 PM
kenchan's Avatar
kenchan
kenchan is offline
alex- when does tirerack intend to update the interactive wheel selector
with the GT7's?
  #27
Old 12-24-2003, 09:16 AM
Alex@tirerack's Avatar
Alex@tirerack
Alex@tirerack is offline
updates come weekly on friday nights, and become visible on Monday morn!
Alex
  #28
Old 12-28-2003, 11:34 AM
10851CS's Avatar
10851CS
10851CS is offline
>>Alex
Alex,
It's Sunday afternoon and I'm WAITING..
Earl
  #29
Old 12-28-2003, 11:55 AM
minihune's Avatar
minihune
minihune is offline
OVERDRIVE - Racing Champion
>>My 03 MCS has 17" S lite wheels on it and I'm getting ready to go up to either 18x7.5's w/215/35's or 17x7's w/215/45's. My question is, if I have 50mm of positive offset in my stock wheels how much offset should I aim for in the new wheels to avoid rubbing after I install my new springs? 35mm, 40mm, 45mm???
The answer is if you keep your stock springs then you can consider offsets from 37mm to 48mm but once you lower your MINI you will need to be very careful how much offset you choose. It all depends on which set of lowering springs you install. For the H-sport the range is 42-48mm offset and for less risk of rubbing try 215/40-17 tires. You can call Randy Webb/Webbmotorsports to discuss offsets.
>>I wish someone would answer my question. I'm looking at 17x7s 4x100 bolt, with a 40mm offset, and 205/40 tires.. Will I rub??!
For the cooper using stock suspension you can use offsets from 37 to 48mm with no rubbing. I'd recommend 215/45-17 or 215/40-17 tires. No rubbing with either if you use stock springs.
Kimolaoha
12-05-2020 09:32 PM
ej
02-20-2016 02:16 PM
weaverpsu
Tires, Wheels, & Brakes
43
11-27-2004 01:04 PM
ulrichd
02-27-2004 07:52 AM
Alex@tirerack
10-04-2002 03:00 PM
Quick Reply: SSR GT7 NEW!!!!!!
