07 MCS TPMS Reset
07 MCS TPMS Reset
I have an 07 MCS coope with rubber valve stems. Up until now, my TPMS has worked correctly when I got a flat or low air pressure. I would correct the air pressure and then reset the TPMS. A couple days ago, though my indicator came up solid red. I check the tires and one was low so I filled all tires to the correct pressure. I went into the menu to reset it and when the tire indicator came up, there was no reset option. I drove the car a couple days about 300 miles and still can not get a reset option. Any ideas?
If the procedure here does not work: How To Reset Tire Pressure Monitor - MINI Cooper R56, R55, R57 https://wiki.bentleypublishers.com/x/AoAUB
http://www.youtube.com/watch?v=c6WJ_...layer_embedded
I would try the reset again. A Red indicator means the system has detected a tire failure. In other words, a tire with low or rapidly decreased pressure.
After several trial and errors, I found the only way I could get to the reset for the tire pressure was to first start the engine, put the car in neutral and then the reset indicator came up.
Previously, I did this and got an error code CC-ID-063 which seems to be the car is in motion while trying this. Hope this may be helpful to future posts.
Thanks for the posts.
hexproject
09-07-2015 08:23 PM
ljmattox
09-01-2015 07:13 PM
DrFraserCrane
08-30-2015 01:11 PM
