TPMS rebuild with new tires?
I dunno what 're-built' means but then again I never understood why new stems was an automatic anytime I bought tires either.
taking a quick look at the tire-rack recommended installers near me I see TPMS service changes ranging from nothing to $15 per wheel . . . looking at per wheel mounting cost it appears the mounting was about $10 more where the TPMS was 'free' . .
So if the charge is $40 for 4 wheels that appears to be about average ... use the tirerack site for a sampling of installers in your area
$40 for one wheel I'd run away . . .
Changing the batteries is not going to happen.. The units are sealed and not serviceable in any way. The may recenter the units or replace the valve stems but if they are mounted properly in the 1st place then there is not need for any type of maintenance unless the tire shop damages them. If you get a bad reading sensor it needs to be replaced and that is the bottom line.
molala
10-02-2015 01:53 PM
