Cooper 08: New brake pads. Upgrade?
Based on your prioroties above, there are 2 choices I'd consider from Hawk
Performance Ceramic - Lower dust is its main advantage
HPS - less dust than stock, and more stopping power than Performance Ceramic
Your OEM pads have alot of stopping power, and as a result make alot of dust. These 2 options will offer a trade off/ or balance of brake power vs
less/lighter colored dust.
Alex
Alex
Here's my 2 cents from an 07 S....I have been going though this for a while. I went with the HPS and thought they were really good - at first. A lot less dust. Good modulation. However, they have a bit less stopping power than the stock pads - it's noticable though. I tried them on the track. I know, they are not a race pad but this was a novice HPDE and I thought they could take it. While their performance was good (no really fade or glazing) the lack of stopping power was really noticable. I have since tried the Hawk HP+ and Carboteck XP 10s and like both of them - but these are both track oriented. And both will be dusty and noisy, but if you can ignore that, they are very drivable on the street. I will probably go back to the stock pads for the street because they feel more like the track pads (less re-learning how to brake), but without the noise. Everyone I have talked to and threads I have read say that unless you are way up in the advanced drivers on the track, the stock rotors or slotted replacements are fine for both street and track. Stay away from cross drilled for the track - they crack...Here is a great thread on this subject
https://www.northamericanmotoring.co...ml#post3074084
hmmm....
I've run OEM pads without exception, and AutoX a lot but do NOT track the car. The OEM pads stop very well, have good initial bite, and are well matched to the rotors (I generally get 2 sets of pads to a set of rotors).
But as you say they are dirty birds aren't they.
So I got a good bottle of wheel cleaner, and a rag supply, and lived with it.
YMMV...
Cheers,
Charlie
YMMV...
Cheers,
Charlie
Based on those recommendations, what rotors would you match up with those?....Could the same rotors be used for track days (e.g. keep the daily driver pads on, swap track pads on for track day, then switch back to daily driver pads)?
HPS for a street pad, HP+ for a track pad - Hawk 9012 Blue if you need more power on the track.
Back to the HPS to drive home, and stop at the pressure wash to clean the cars and wheels off after the track event, of course once they are cool.
Alex
And if you switch to carbotech XP10's or XP8's for the track (I think we were talking about this in another thread), the base pad material is similar enough that you don't have to scrub the rotor clean; you can go back and forth from Bobcats to XP's without worrying about getting the old pad compound off and the new one on the rotors.
On Alex' recommendation I purchased the Hawk Performance Ceramic pads with Centric Premium rotors and had them installed. The pads feel as if they are bars of soap. Trying to stop is scary. Alex said that the modulation would be improved with these pads but there is no modulation, just full on or off. Has anyone else had this experience? I'm assuming that once they are bedded-in they will exhibit the performance that I expected.
I can't imagine how the installation can be at fault.
Any suggestions?
Any suggestions?
Ceramics are nice and firm feeling, but lacking initail bite.
HPS is easier to modulate and has more brake power.
Any suggestions?
Alex
07-16-2020 12:54 PM
08-07-2015 05:55 AM
PelicanParts.com
08-04-2015 02:45 PM
