Longer Wheel Studs for R56 Mini?
I would like to convert my 2009 Mini JCW to wheel studs and I need to accommodate a 15mm wheel spacer. The stock wheel bolt is approximately 50mm long so I will need to get wheel studs that are approximately 65mm or longer assuming the lug nut is about the same length as the wheel bolt head. The only M14x1.25 wheel studs I can find are in the 50mm range.
Any help is appreciated. Thanks.
07-16-2020 12:54 PM
SosoMINI
11-22-2015 03:17 PM
