Any advice for an upgrade to 16-inch wheel?
Since you won't be seeing any snow or frigid weather, I suggest a set of
Enkei Racing PF01 or RPR1 16x7 wheels (+43mm offset, about 14# - semi-forged - strong and light),
and Dunlop Direzza Sport Z1 Star Spec tires in 205/50/16 from Tire Rack.
If you want to get a truly forged wheel, the Volk CE28N wheels would be great, but they're
about $200 more each (16x7 +42et), and you'll have to look around
a bit to find some.
a bit to find some.
Although Volks are out of almost everyones price range, I thought I'd add that Volk now makes a stronger but slightly heavier cousin to the CE28N, the RE30. Looks similar, but +40et instead of +42.
Here's a link.
http://www.upgrademotoring.com/wheel...acing/re30.htm
Here's a link.
Cristo, given that you're the only one to offer advice, you're a hero. And a nice racing rim is a wonderful thing. At $600/ea. that's a good thing to be.
Wife is grinning. "Volk" (people in German) for the majority that can't afford them.
postings of mine from another thread, that apply to your inquiry:
I recently bought a second set of rims (OZ Allegerittas 16x7 in Anthracite) and wrapped them w/ Continental ExtremeContact DW's 205/55ZR16. BIG difference in ride and handling. And the price for those tyres isn't that bad either.. less than $100 per, for a Z rated tyre.
Here's the pic I took after I installed them on Branwen. http://www.facebook.com/photo.php?pi...2&id=667780938
they are a lot easier to handle (cleanliness wise) than the stock White Bridgespokes... http://www.facebook.com/photo.php?pi...b&id=667780938
According to my order history on Tirerack... $1456 was the item total +$88 for shipping. $1544 out-of-pocket. All I had to do was reomve the old ones and install the new ones; they came mounted and balanced at no charge. Although, I did have to wait almost a month for them to arrive because of the backorder on the centering rings from OZ... but it was worth the wait!
Like 'cristo' I have to recommend the Enkei RPF1's. They are a very light, 13.8 lbs, strong wheel.
I went from stock wheels and non-runflats to 16 inch RPF1's with Michelin Pilot Exalto PE2's in 205/50/16 and could not be happier.
They're over 11 lbs. less per wheel and tire than before and the result is a better and more controlled ride.
Hope this helps...
Hope this helps...
When I was about to place my own order on the 16" OZ Allegerittas, I was also unsure whether to go +42 or +37 offset. I took the plunge and went with +37 since another member who got the same wheels said +37 gives the wheels a more flush look to the wheel arches. And I do agree that it really looks much better than how the oem wheels looked at stock +48 offset.
07-16-2020 01:54 PM
08-07-2015 06:55 AM
08-05-2015 03:11 PM
