RPF1 15 inch on MCS
RPF1 15 inch on MCS
As the title suggested, I would like to know if Enkei RPF1 15 inch will fit MCS R53 without any problem.
Car is standard brake and the only thing i am buying the RPF1 is the weight, as some people have suggested Enkei RPF1 is not the most attractive wheel out there.
Would be great if someone can point me in the right direction and pictures would be excellent.
Thanks once again
Thanks once again
on
As long as the brakes are stock size, and you arent trying to stuff 15X8 or wider wheels they should fit witout a problem. You can go wide but tires need clearance too. The person to ask would be Rally at Stance Design. there is a good thread on wide wheels mostly 15s called ROLL CALL 8" WIDE, use the search button.
Also check out the RPF-1 Type 2, it has a not so Japaneese look.
For the 15" RPF1, you need to do a little modification. https://www.northamericanmotoring.co...-on-a-mcs.html
on
PF01 sounds like it might fit the R53 JCW calipers, since they say the wheels were designed to fit bigger brake set-ups. I am considering 15x8 PF01s, just having some financial dillemas ala tickets, insurance, deductibles, scratch removal and some paintless dent removal work needed to be done. But next month should be better.
how do these tires/wheels effect the ride?
Right now my car is lowered and on 17's with stock sized tires (non runflat) and its a little too jarring for me...
I dont need the best handling but would still like to have better then average...
Would jumping down to a 15" wheel with more rubber give me a softer ride?
on
Generally, yes, but it all depends on tire size.
wildwestrider
12-27-2015 08:20 PM
M7Speed
09-04-2015 10:47 AM
F55/F56 Seat question (non-sport seats)
SeattleF56
09-03-2015 03:01 PM
