Will These Fit 2009 Clubman S?
Hi,
Been searching for winter set of tires and wheels for my 2009 clubman S.
Will these fit? Specifically I understand need certain wheels to clear the S brakes?
https://www.northamericanmotoring.co...?product=13395
Thanks.
Jeff
Thanks.
Jeff
I think the 16" wheels will fit just fine, its the 15" wheels that have the problem I believe. But check the stud size, if I remember they changed to 14x1.25 in 2007 and that's different than previous models. I could be wrong, as I don't remember 100% hopefully someone who remembers right will chime in.
Hi,
Thanks.
Jeff
Thanks.
Jeff
The 2009 and older OEM 16 inch wheels that fit your Clubman S are: R-94 Bridge-Spoke, R-102 S-Winder, R-103 Blaster.
The new 2011 OEM 16 inch wheels, shown on the MINI configurator, will of course fit.
The TPMS system was changed in 2010 and forward.
Hope this helps...
Hi,
Another question.
Please refer to this ad: http://cgi.ebay.com/ebaymotors/16-Wh...ht_4775wt_1165
And specifically this:
"These are original equipment Toyota wheels, not aftermarket wheels. While these are original equipment from a Toyota, all the dimensions are the same as for the cars listed above except for the hub size. These wheels have been modified by increasing the center bore size (by only 2 mm) to fit the vehicles listed here. This is done in a machine shop to very high tolerances and does not affect the strength of the wheel, nor the look of the wheel. These wheels remain hubcentric for all the vehicles listed. You will not need hub rings as you would for aftermarket wheels. We have been doing this modification on various wheels since 2000 and have never had a problem."
Should I be concerned?
Will these fit a clubman S 2009?
Wheel dimensions: 16" x 6.0"
Offset: 45mm
Bolt pattern: 4x100 mm
Thanks!
Jeff
Another question.
Offset: 45mm
Thanks!
Jeff
Hi,
Another question.
Offset: 45mm
Thanks!
Jeff
Another question.
Offset: 45mm
Thanks!
Jeff
Also 16x6 is a little narrow, depending on the width of the tires you get.
08-12-2015 01:24 PM
