16x8 +0 offset fit on rear of an r56??
on
Hey everyone .. I'm looking at some wheels for the mini , the fronts are 16x7.5 + 38 offset which I know will clear and fit perfect... But for the back it's a 16x8 +0, does anyone know if they will clear calipers and not look ridiluously out of the fender?
It's likely you will. Take it to a good shop that does hellaflush wheels.
see
http://forums.club4ag.com/zerothread?id=53302
For example this is 205mm wide tires on an 8" wide rim
![Name: stretch1.jpg
Size: 81.4 KB](https://www.northamericanmotoring.com/forums/attachments/tires-wheels-and-brakes/174362d1502131792-16x8-0-offset-fit-on-rear-of-an-r56-stretch1.jpg)
The rear 16x8 will stick out quite a bit.
Some negative camber will help the reduce the difference on the upper edge of the tire from the wheel arch. Adjustable lower control arms will help.
Realize that excessive rear negative camber will increase tendency to understeer so don't turn corners too fast. Tire wear on the inside edges of the rear tires will be higher.
see
Yes, severe offset and very wide on the road surface with very large slant inward to "sort of" fit.
![](http://culturegarage.com/images/sized/images/uploads/3959619250_1bc6c7381a_b-498x0.jpg)
severe negative camber
Another option is to go with tires that are much shorter than stock which will give enough clearance to not hit the wheel arches and yes it will stick out.
Never mind the negative camber.
![](http://img.photobucket.com/albums/v489/xok/DSC03227.jpg)
I'm sure this owner thinks his wheels fit fine.
on
Yea those wheels aren't gonna work... I've been also looking at these esm 009r wheels that are 16x8 with both +30 and + 20 offsets? You think I can make the +30 offset work all around??
http://www.esmwheels.com/main/produc...sjs5d4n9cgddo2
+30mm offset and 16x8 it will still stick out a little more than a 1/2"
07-16-2020 12:54 PM
SosoMINI
11-22-2015 03:17 PM
Mini'mon
08-16-2015 04:15 PM
08-12-2015 01:24 PM
