hub centric rings question
First of all, the hub size on a MINI is 56.1mm. Secondly, the hubcentric ring needs to match both the car and the wheel. The outer diameter of the ring will be the same as the inner diameter of the hole in the wheel.
So if you have a wheel with a 67mm bore and a car with a 56mm bore, you need a set of 56-67mm hubcentric rings.
--Dan
Mach V
--Dan
Mach V
thebordella
08-31-2015 01:37 PM
DrFraserCrane
08-30-2015 01:11 PM
jrezzo
08-09-2015 10:32 PM
