R53 vs. R56 MCS wheel compatibility
Okay, so assuming the bolt holes on the wheel are ø2mm larger, the wheel bolts being acorn bolts, won't the taper cause them to cinch up and tighten anyway?
Correction: Under the assumption iwashmycar is making, then there is nothing holding you back from mounting the R111's.
Again, according to the information in this thread, all MINI wheels have a 14mm lug hole in the face of the wheel.
You will continue to use your 12mm lugs given that those are what fit into your wheel hub (the actual deciding factor).
07-16-2020 12:54 PM
O4mcs
08-06-2015 05:42 AM
