Venting a little: second Low Pressure warning in 2 days.
on
Just had my tires/wheels/swaybar done in one shot at a local Big O Tire.
The day of, I drove it to work on surface streets with no issues, but on the way home on the highway it vibrated like crazy at speed, mostly felt in the steering wheel. Brought it back to the shop immediately. On my way there, a half block from the service bay, the Tire Pressure light came on.
I told them that in addition to the vibration we had spoken about on the phone, I also had a tire pressure light. I assumed they had just done a sloppy fill job and it was out enough to throw things off. They had it on the lift for a bit, told me one wheel was slightly off balance, and they filled the tires.
Then today, after a leisurely highway drive, the light comes on again, luckily, right beside a gas station. I pull in and check the tires, all are at 34, but one is barely pushing out the rod on the pressure gauge. I thought I was just not getting a good seal, but nope, it was around 15psi.
Is there something other than tire damage that would explain this kind of slow-ish leak? I haven't hit anything and I don't see any nails, etc. Could this be the result of poor workmanship while mounting the tires?
I'm bringing it in first thing tomorrow morning. I just want to enjoy my new wheels and tires!
Nice to know the system works, eh? Probably saved you buying another tire.
I think JPMM is right, it's leaking around the rim. Need to dismount and clean the rim with a scotch pad, then remount it.
They usually replace the valve stems, so it's unlikely that's what's wrong but it's possible, they could have damaged it while putting the tire on or it could have a bad stem.
on
Thanks for the input guys. Definitely good to know the system works, but I'm surprised it took a 20lb difference to light up! I'm also surprised that the tire didn't look flat with only 15psi.
I brought it in first thing this morning. I was initially told that it looked fine, but when I pointed out that it was the second time it had happened since they mounted the tires, the owner overheard and stepped in. He had them remove the tire, clean it and re-seal it. They said it also may have been the stem not seated properly but could have been repositioned properly when I filled it last night (?)
In any case, hopefully it is resolved now. There is just one employee there that is a pain to deal with, but the owner has been good at trying to resolve things as they have come up. Some good news, he told me my Konig decals for the caps should be in today or tomorrow. It looks a little naked as-is.
07-16-2020 12:54 PM
