so i bought some eniki rims from tire rack they saiiiddd i could use oe lug bolts problem is the holes the oe lug bolts fit in are not the ones that line up im very very upset and idk what to do . the other holes that line up are super small and idk if they have like tuner thin lug bolts . i spent over a grand in tires and rims and now im stuck please help
Your car has 12mm lug bolts. Which Enkei wheels? Have you discussed this with Alex at TireRack? They are pretty good folks and have answers for about everything.
no i havent not yet how do i get in touch with him ?. and is the thread size 12 mm because i know it takes a 17mm socket . im just worried im sh*t outa luck because idk if i can find small tuner lug bolts to fit if that is the problem
Be very carefull with the set from Gorilla, as they are a bit shorter than the stock bolt by about 3mm. Should be fine as long as you don't need wheel spacers.
