Tire Pressure
Old 05-21-2011 | 08:04 PM
or birdman's Avatar
or birdman
Tire Pressure
For Autocrossing with my 78 mini how much tire pressure should I run. I have 165/10 Yokohama AO32s
Old 05-25-2011 | 02:14 PM
Alex@tirerack's Avatar
Alex@tirerack
That's a tricky one, Your car is SO light, I'd guess 34-36 lb range and adjust with a pyrometer's (probe style not IR) help.
These newer cars use much higher pressures, but they have more mass to deal with. It also helps to have a friend that can take the tire probe temperatures - you'll be loosing heat pretty quickly.
I think you'll also want to make the adjustments based on sidewall flex - I am thinking lower pressures to aid in the build up of heat.
Alex
Old 05-26-2011 | 03:12 AM
or birdman's Avatar
or birdman
Originally Posted by Alex@tirerack
T
Alex
That's what I did. Put shoe polish on the tires so I could see where it wore off. Ended up at 21 lbs pressure.
Old 05-26-2011 | 04:02 AM
cmt52663's Avatar
cmt52663
A friend with an adult kart is in the 11-14 lb range. Of course the kart weighs more, and has larger wheels...
07-16-2020 01:54 PM
khumpert
11-30-2015 12:48 PM
oldkid6
08-30-2015 09:28 AM
TJANK
08-24-2015 07:11 PM
nomar116
08-09-2015 10:42 AM
