help!! lug bolts too big! (first post)
bitesize: Sorry, but I'm still trying to learn about wheels for the MINI myself, so the two posts confuse me. Do you mean that the OEM lug bolts are too large in diameter to fit through the bolt holes of the wheel? If so, that might mean the wheels are designed to take the earlier OEM 12 mm bolts rather than the later OEM 14 mm bolts?
HRM: My probably incomplete understanding of tuner bolts is that they have a cone shaped seat rather than the OEM ball shaped seat, but come in various diameters. Thus, I'm confused about why tuner bolts would necessarily be the solution to the diameter problem. I would appreciate some enlightenment.
If you have the 14 mm hubs (after 2006), then maybe you need the studs that convert
from 14x1.25 to 12x1.5 such as these (along with 16 nuts to go with them):
http://www.waymotorworks.com/m14-to-...rsion-kit.html
If you have 12 mm hubs but the oem bolts are too big, then you might need narrower tuner bolts
that are designed for your aftermarket wheels. In that case, whoever sold you the wheels should
know.
know.
The bolts are not too big usually, the opening for the lugs is too small to fit a socket in. If the socket won't fit, you can't tighten the bolts (which actually fit fine) Tuner lugs (and maybe others) use a skinny sleeve to tighten and loosen the bolts. The skinny adapter fits where a normal socket won't.
on an old set i had..same issue.. stud diameter too big for rim hole!!
what i did though was drill the rim stud hole..if your patient and have the right tools it can be great..
i put rim flat and the drill bit i had ( not sure what size it was anymore) any how it was a smidgen bigger than the pre existing hole which was just big enough for stud to fall through..in my case i was still able to get my socket securely around nut...plus that fact that i did it slow and as straight as possible..and i also has hub rings and all to center it well ...
i know its not always recommended but it worked well for me!!
I've had the 14mm -> 12 mm conversion studs on my '06 for 80k miles with no problems (other than the black phosphate coating wearing off quickly, causing a little bit of surface rust on the studs.) They're very sturdy, and it makes it so much easier to swap out wheels since you can just slide the wheel onto the studs rather than having to rest the wheel on the hub lip and then line up the bolt holes in the wheel with the holes in the hub.
on
Take the wheels back before you kill you or somebody else
If the lug bolts won't fit through the holes on the new wheels you can't just use skinny lug bolts. (Not Possible) If you can you need to take the wheels back for a refund or exchange for the proper wheels that are for your car.
Even if you replace the lug bolts with studs they will still be just as thick and still won't fit into the small wheel lug holes.
The Wheel lug pattern may not even be the same as your stock wheels.
Keep your car safe to drive and don't take a chance on trying to adapt something that does not fit such as a wheel.
It is important to remember that if you go with the conversion studs, you should use 88 lbf-ft as the proper torque when tightening the lug nuts, rather than the 103 lbf-ft that the owner's manual recommends for the 14 mm lug bolts.
Reviving this thread here with a few more questions on this topic. I got some 949 racing wheels that have the 12mm holes. If I buy the stud conversion, does anyone know if they are strong enough for track use? I see the Way Motor Works ones that someone mentioned, also found some made by Wheelmate that are half the price:
http://www.evasivemotorsports.com/mm...HEELMATE-STUDS
Anyone have experience with these?
Finally, and most important, Does anyone use these without the recommended Loctite? I would like to be able to remove the studs to use my stock wheels. I've talked to at least one racer who says the Loctite is not really necessary if torqued properly. Anyone have a second opinion on this, or better yet, any actual experience?
Thanks,
DD
Thanks,
DD
Thanks,
DD
Thanks,
DD
Thanks,
DD
Thanks,
DD
Red is for bolts you really don't want to have to pull back out, where blue makes it a pain to get bolts back out, LOL. (red is stronger)
How do you loosen red Loctite?
A: The best way I have found is with heat. And lots of it.
Hmmm. I may have to re-think this whole idea. Thanks for the replies. Don't really want to re-drill the wheels.
May just sell the whole set-up and start over. Didn't realize when I bought the wheels that they were 12mm, and mounted the tires before I checked fitment. I don't really mind using studs- actually, I like the idea, except that my street wheels are 14mm.
Gil-galad
Eastern Iowa MINIs
63
11-17-2016 02:54 PM
minipopkart
08-13-2015 05:22 AM
