tWO QUESTIONS ABOUT TIRE SIZE
Heres my first question Ihave a 195/50/r16 tire how tall is it i think its the 195 number but my friend insists its the 50 # ........ Next is i plan on putting 17 on my mini cooper i have only found 205's what i dont want is to gain rollout this will throw my gearratios of is the diffrence really that bad ar can it be gainded back with exhaust an intake mods ?
thanks for ur help guys
Your friend is correct, the 195 is the width in mm of the tread, while the 50 is the sidewall aspect ratio / half of the width in height. If you go with stock sized 17" wheels, a 45 sidewall height should work out fine. No problem with the speedo / gearing. 205s will be fine, 215s are the max and might result in minimal body rub with some offsets.
_________________
BLUBELLE - 2003 MCS IB /W Premium, Sport, Cold pkgs, Lapis blue interior, Magnecor wires, Alta Pulley, Moss Skid Plate, Chrome Trim Interior
_________________
Try this useful tire size comparison calculator :
Tire Size Comparison Calculator
Here's another :
Tire Size Comparison Calulator 2
Here's another :
col127
08-21-2015 02:11 PM
