Bbs reps?
on
on
Oh and also on a different note. I found some wheels I like and the center bore is 72.6. If I get some hubcentric rings that are 73mm and size it down to 56.1 will that be adequate? Are the 73mm rings for 73mm bores? or 72.6's? Are they just rounding up? AKA Outmotoring.com's offerings..
Thanks ahead of time.
However, ESM Wheels does.
Example, the 72.6mm to 56.1mm centering rings have an outer diameter of 72.6mm to fit into the wheel center hole...
And a 56.1mm inner hole to accept to the suspension hub.
And typically, rounding IS NOT common. Find out the exact details of the wheels in question.
- Erik
F55/F56 JCW Pro Coilovers... on a Justa
MidnightF56
09-10-2015 01:04 PM
