Airaware TPMS Question
I am looking for TPMS sensors for my Snows. I ran accross TMPS sensors stocked at Autozone manufactured by Airaware for $18 a sensor. This seems too good to be true, but does anyone know if these would even work from my 2010+ Mini?
http://www.autozone.com/autozone/par..._210679_10706_
First, you need to look at if you're buying a replacement sensor that sends out the same transponder as the BMW / Mini frequency...
Or if your buying a sensor that's designed for a retro-fit kit that has a seperate control / monitoring module (like how most AirAware kits are sold).
Seeing that part number you pulled [AirAware #20037] and cross-referencing it on the web, it appears it's a replacement TMPS for existing OEM systems.
However, I would get a hold of AirAware directly and ask on their applications to verify it's a working TPMS for the BMW / Mini frequency.
- Erik
EDIT: Found more information; AirAware appears to be a sub-set of Schrader International
* http://www.schrader-bridgeport.com/?page=tpms
There part number align with the details you provided; but it's not 100% clear what's needed.
- Erik
I was able to uncover that the part I referenced prior is in fact only a valve stem core without a transmitter. The Transmitter part is 28081 and sells for $177 at Auto Zone, plus the $19 Valve... I would be better off getting the OEM ones from the Dealership.
Research----
http://www.loomisrootinc.com/uploads...ms_catalog.pdf
http://www.autozone.com/autozone/par...er=269844_0_0_
Research----
molala
10-02-2015 01:53 PM
