Rear Brake Caliper Piston
The Bentley Service Manual (2007-2011) says that you need a special tool to move the rear brake pad piston, because it "turns the piston while pressing in." [I used a generic disk brake pad spreader just fine on the front pistons.]
Samstag Sales sells such a tool. However, when I emailed them to find out if it would work on a 2nd gen MINI (i.e. 2007-2011) they basically said they didn't know.
So, my question is: Will the same special tool that is used to move the rear brake caliper piston on a 1st gen MINI (thru 2006) work on the 2007's and later?
I happen to have a 2007 Cooper Hatchback.
07-16-2020 12:54 PM
