Question about offset
Old 01-20-2012 | 05:13 PM
davisflyer's Avatar
davisflyer
When looking at offset on a wheel, does a higher number mean it's closer to the inside or the outside of the car? Does adding a spacer increase or decrease the offset?
Old 01-20-2012 | 06:16 PM
Creeve's Avatar
Creeve
higher means closer to the inside. spacers lower offset
Old 01-20-2012 | 06:25 PM
miniconcarne's Avatar
miniconcarne
Old 01-21-2012 | 09:48 AM
davisflyer's Avatar
davisflyer
OK, so if I'm looking at getting a wheel with a 40mm offset, if I get a 5mm spacer, it will push the wheel out further, correct?
Old 01-21-2012 | 12:09 PM
bluefox280's Avatar
bluefox280
Correct, as the overall offset would be (40mm - 5mm = ) 35mm.
- Erik
Old 01-21-2012 | 12:12 PM
kazlot's Avatar
kazlot
Creeve & Bluefox280
What they said...
Old 01-21-2012 | 01:15 PM
davisflyer's Avatar
davisflyer
- Erik
OK, with that part settled, how little offset can i get away with on stock 17" tires without rubbing?
Old 01-21-2012 | 06:43 PM
bluefox280's Avatar
bluefox280
Well remember, offset is in relation to the wheel width, and not the diameter.
What's the width of the wheels you want to run with the 40mm offset?
- Erik
Old 01-21-2012 | 07:13 PM
Eddie07S's Avatar
Eddie07S
Offset also affects torque steer. The less offset that you have the more torque steer. This is why fwd cars have so much offset. It also affects how much load you put on the bearings; the less offset (the more the wheel is outboard from the center of the car) the more highly loaded the bearings are and the faster they will wear out.
Old 01-21-2012 | 09:07 PM
davisflyer's Avatar
davisflyer
Good questions!
I'm looking at a couple different wheels, 17x7 with 38mm and 40mm offsets respectively.
Old 01-21-2012 | 09:27 PM
bluefox280's Avatar
bluefox280
That's only 8-10mm difference than the OEM 7" wide wheels @ 48mm offset; you'll have zero problems.
- Erik
Old 01-21-2012 | 11:09 PM
davisflyer's Avatar
davisflyer
- Erik
schwac2
06-14-2016 05:06 PM
actualsize37
11-18-2015 09:58 AM
donniedarko
10-21-2015 02:15 PM
