Show me your WHEELS! 2.0
Old 07-06-2013, 07:17 PM
DVUS CPRS's Avatar
DVUS CPRS
DVUS CPRS is offline
exactly what I want. Beautiful wheels.
Originally Posted by aytch1
  #527
Old 07-08-2013, 09:11 PM
retrophusion's Avatar
retrophusion
retrophusion is offline
Newest set on for a test after powder and polish... 17x7.5" ET35 BBS RK II's
  #528
Old 07-08-2013, 09:17 PM
RedAndBlackMiniS's Avatar
RedAndBlackMiniS
RedAndBlackMiniS is offline
Originally Posted by Trizzz
New BBS of you just refinished them?
What are the specs?
I refinished them. They are 17x8 ET20.
Originally Posted by jibber11
Beautiful
Ugh but I have nightmares thinking of the weekly car wash.
Thanks. They are an absolute pain to keep clean, but so worth it when they are actually clean.
  #529
Old 07-09-2013, 07:01 PM
Richard_rsp's Avatar
Richard_rsp
Richard_rsp is offline
I picked up a set of TRMotorsports C1 wheels in 16"x7" with 205/50/R16 Continental Extreme Contact DW tires from TireRack. I bought these to replace my OEM 15" x 5.5" R118 5-star Twin-spoke wheels.
Before:
After: (sorry for the crappy pic, it was getting dark)
Difference in width:
As far as weight goes, it looks like I only gained 3.8lbs in going to the 16x7s over the R118s (R118 w/ OEM Conti All-seasons = 31.0 lbs, 16" TR Motorsports C1s w/ Conti ExtremeContact DW = 34.8 lbs, measured on bathroom scale), so I'm pretty happy with that!
  #530
Old 07-11-2013, 09:09 AM
darthhen's Avatar
darthhen
darthhen is offline
17" Drag DR-34 on Clubman
I got these wheels over the 4th of July week. And I received my Mini center decal replacement yesterday.
  #531
Old 07-15-2013, 12:34 PM
TG.'s Avatar
TG.
TG. is offline
I like those! . . . if only they didn't have to make it multi-car fitment. I know it's probably just me but wheels with too many bolt holes drives me crazy
  #532
Old 07-15-2013, 02:38 PM
OdzBodkinz's Avatar
OdzBodkinz
OdzBodkinz is offline
I just put on some Borbet BS-4's in 16 inch with new Yokohama rubber.
  #533
Old 07-16-2013, 05:15 PM
ZigZagN's Avatar
ZigZagN
ZigZagN is offline
Originally Posted by miniscool
Raiden D01's 17 x 7
I love the wheels and would like to buy a set for my Mini.
I've googled Raiden, but cannot find a location in the US to purchase these wheels. Where did you purchase your Raiden wheels?
  #534
Old 07-18-2013, 09:26 PM
Nicolio21's Avatar
Nicolio21
Nicolio21 is offline
2008 mini cooper S... 17x8.5 FIFTEEN52 TARMACS
  #535
Old 07-18-2013, 09:44 PM
jordan.burks's Avatar
jordan.burks
jordan.burks is offline
those are badass!
  #536
Old 07-19-2013, 11:31 AM
400mphpc's Avatar
400mphpc
400mphpc is offline
2008 R56 MCS. Plasti dip trim rings on the factory clubman wheel to remove the curb rash from the previous owner. 4 to 5 coats of plasti dip and 2 coats of glossifier. Also painted the lugs red.
Attached Thumbnails Show me your WHEELS! 2.0-1.jpg   Show me your WHEELS! 2.0-3.jpg
  #537
Old 07-21-2013, 08:17 PM
Tortie's Avatar
Tortie
Tortie is offline
16" Rota Grids in white.
  #538
Old 07-27-2013, 10:32 PM
metalfreaxxx's Avatar
metalfreaxxx
metalfreaxxx is offline
just fitted the XXR 527
  #539
Old 07-28-2013, 06:48 AM
Minibeagle's Avatar
Minibeagle
Minibeagle is offline
+1,000,000,000,000
  #540
Old 07-29-2013, 11:17 PM
atraain's Avatar
atraain
atraain is offline
Originally Posted by palax919
finally got the right stance and fitmet...
I like these, have you had any complaints for these wheels? I'm thinking of getting some of these.
  #541
Old 07-30-2013, 04:53 PM
atraain's Avatar
atraain
atraain is offline
Im thinking of getting these wheels for my 2004 MCS, but ESM only makes them in 15" 16" and 18". Will 18"s fit on my car and also can someone point me in the direction of some kind of guide to picking the right wheel for my car? I dont know what all this offset business is
i also dont know what all this means...
118x8.5 and 18x9.5.
Size/ Bolt Pattern Offset/ Center Bore/ Lip Size/ MSRP (USD)/ In Stock
» 18x8.5 5x100/112 35 66.6 2.0" $155/wheel Yes
» 18x8.5 5x120/114.3 20 74.1 2.0" $155/wheel Yes
» 18x8.5 5x120/114.3 35 74.1 2.0" $155/wheel Yes
» 18x9.5 5x100/112 38 66.6 2.5" $175/wheel Yes
» 18x9.5 5x120/114.3 15 74.1 2.5" $175/wheel Yes
» 18x9.5 5x120/114.3 40 74.1 2.5" $175/wheel Yes
  #542
Old 07-31-2013, 04:12 PM
mini coop's Avatar
mini coop
mini coop is offline
Size of wheel and width.......for an R56 it 4 bolts not 5 and the pattern you need is 4x100. The less the offset the further the outside edge of the tire will approach the edge of your fender or the black trim around your wheel well. It moves the wheel further out from the car. Center bore is the hub size that fits inside the center hole of the wheel (behind the esm logo). Lip size is how far the edge is out from the center of the wheel. Hope that helps and others will have additional explanations. Tirerack will show what fits on your car. ....15,16,17,18 inch wheels fit on an R56. Guaranteed.
  #543
Old 07-31-2013, 05:16 PM
atraain's Avatar
atraain
atraain is offline
I have an r53, can someone explain off set and everything else when choosing the right wheel? I'm thinking of getting some ESM's that only come in 18" will they fit?
  #544
Old 07-31-2013, 06:50 PM
mini coop's Avatar
mini coop
Go to the Tirerack website. It has all the information that you need regarding offset, diameter, circumference, sidewall height, and ratios as in 175/65/15 etc. They can explain it for you. Or call our Tirerack rep Alex. Discount Tire Direct has the same info in the Info Center. Good luck.
  #545
Old 07-31-2013, 11:29 PM
atraain's Avatar
atraain
atraain is offline
I understand center bore size, and what off set is, but what I don't get is what does more off set mean, and what does less mean for the drive? Am I clear? Like what does it do?
I want these but idk which option is good for me http://esmwheels.com/access/esm-007-16-hsl-p-206.html
  #546
Old 08-01-2013, 05:37 AM
TG.'s Avatar
TG.
TG. is offline
Assuming the same tire/wheel width for the moment, a lower offset from OE pulls your wheel outward. This provides increased stability to the car, marginally reduce the turning radius, add some additional strain to the wheel baring in the long run, and potentially add unexpected uneven wear to the tire. It may change the dynamics of the car in over or under steering. Higher offset will pull the wheel inward from OE which as some of the reverse effect of lowering offset such as stability, turning radius, over or under steering. Still has some added strain to wheel bearings, but more importantly may interfere with the suspension component (especially shocks) in some cases especially when the car rebounds and the wheel drops down. Lowering the car can partially compensate for that aspect sometime.
Knowing this, all is a give and take and manufacturer run into the same choices to cover different wheel size and tire options.
When you can, what you can do with offset is to use it to re-balance some of the geometry when changing the wheel/tire width. More grip but also more drag and weight.
Overall changing offset marginally isn't too critical as long as clearances are met but you might incur more wear on wheel bearings and tires and change the steering dynamic a little. Just something to consider, not to stop you...
  #547
Old 08-01-2013, 08:51 AM
Brandin Sharp's Avatar
Brandin Sharp
Brandin Sharp is offline
XXR 522 15x8 et0 wrapped in Kumho Ecsta AST 195/50R15
The third picture was taken before the first two, hence the different colored hood and dirt (How embarrassing! Hard to clean working 90 hours a week ). I flipped my car early last month and have been trying to pull him together between work and school starting in 2 weeks.
  #548
Old 08-01-2013, 09:00 AM
jhull413's Avatar
jhull413
jhull413 is offline
Just curious, why the screws in the front wheel arch?
  #549
Old 08-01-2013, 09:06 AM
Trizzz's Avatar
Trizzz
Trizzz is offline
Drop your car and Poke the wheels! :D
It will be awesome!
nice car, love the matte color
  #550
Old 08-01-2013, 09:15 AM
Brandin Sharp
As much as I have my MINI apart, I find it far easier to unbolt rather than taking the flares off and breaking a few clips (I hate those things!). Plus, I personally like the look.
It will be awesome!
Thank you! That's definitely coming soon. The color probably won't stay; I'll stay with blue, just probably in a darker, more saturated blue. I have a two-page-long to-do list for my MINI. Since I'll be starting at the NASCAR Tech in a couple of weeks, it'll be the perfect time for it!
Quick Reply: Show me your WHEELS! 2.0
