Show me your WHEELS! 2.0
#780
Rotiform NUE et30 17x8 with P225/45R-17 Pirelli P Zero Nero All Season Run Flats
I do get some rubbing in the back when I pack the car up and hit bumps or dips in the road. Doesn't look like my inspiration photos had that issue.. any thoughts?
The attached photos were my inspiration...
#781
#782
Why it worked for us: 1. We are all lowered 2. We have a crap load of negative camber in the back to tuck the wheel in 3. We all run undersized tires. At least for me, I ran 205/40s. 225/45 is way too wide for a flush look. If you plan on lowering it, you need smaller tires.
#783
#786
#787
#789
So I reached out to Rotiform and they told me that I should put electrical tape around the hub to fill the gap because I wont find a spacer that size. They also suggested that the 1mm gap shouldn't cause a problem; I can assure you that there is vibration and something is not right, and my only logical guess is the 1mm gap.
Did you have vibration issues?
#790
2. why the tractor tyres? 205/14/17 really is the maximum you should be using on wheels with this width and offset
3. mudflaps need to go
#793
1. Coilovers are on my list of things I've thought about buying, but the "tractor tires" I currently have would not tuck. Also, my car has the Sport Suspension option, would coilovers perform better? I also like the outdoors and don't want to lower my car because I need to take it on gravel roads and dont want to have to worry about clearance.
2. I wanted all season tires because I didn't want two sets of wheels again (summer and winter). Also, I wanted runflats; I got rid of my runflats on my 135i and lost a lot of the stiff turn-in feel (I didn't want to loose any of the go-kart type feel on this car). Stretching runflats did not seem like an option. So 225/45 is the size I was stuck with. I was also not familiar with stretching tires and what would look best.
3. Had to have the mudflaps with this setup; my paint was taking a beating with all the sand and rocks on the road from the winter.
#795
original holies
love the classic look of the original holies...
125,000 miles and going strong
(second set of holies with blizzaks mounted for winter)
9 Minnesota Winters-still a beauty! by jimmy_racoon, on Flickr
#796
Summers are finally on
17 x 7.5 Black Sparco Pro Corsa
215/45ZR17 BFGoodrich g-Force Sport COMP-2
Just came in. Two months back ordered but well worth the wait.
That and some other projects I did over the past week.
https://plus.google.com/photos/11843...28689144868945
#797
#800
