Here's one for you Alex..18x7.5x45mm with....
new 205/40-18 Michelin Pilot Sport 2's due in June. Is the 45mm offset going to get me in trouble with the strut housing? I am close now with my stock 17x7x48mm with a 215/45-17 pzero. I appreciate you opinion, thanks!
P.S. Section width is 8.4" on a 7.5" rim and 24.4" Diameter.
These new michelins are the bomb and have suprisingly supple sidewalls (are supposed to be a quieter smoother riding tire (not to mention F1 sticky) than the pilot sports.
I am running a 225/35/18 on SSR comps with no problems, section width is 9.1" , dia. is 24.3", also the rim is 18x7.5, +42mm offset....There is room left on mine if you want i will measure, i also have coilovers and still doesnt rub, i did have stock and also had no rubbing problems.. Hope this helps you some....
The new 18" JCW wheels will be fitted with 205/40-18 Dunlop SP Sport 01 DDST tires. This wheel is only 7" wide but has a 52mm offset and requires a "steering stop" retrofit kit.
I think you should be OK with a 45mm offset.
Mike_Mini2
05-09-2024 10:28 PM
Navigation & Audio Help needed with suggestions for Audio upgrade.
DreamingTwig
12
07-01-2010 10:52 AM
