Lightest OEM wheels for 17's?
Centerline are about as light as you are going to get in white, 12 pounds lighter then the boat anchors you have coming.
_________________
Brake Light Mod, Clear Armor Bra, Schroth Racing Harness, M3 Pro Helmet. SSR 6.5x16's & V700's.
_________________
>>Wondering which stock MINI 17" wheels are the lightest- my S is coming w/ 17" white alloys. It's CR/W, and I really like the look of white wheels to go w/ the roof and mirror caps. Anyone have some ultra light after-market white wheels they'd recommend?
Stock 17" wheels for the MINI would be the very heavy and expensive R90 two piece Italian Job spoked rims at 24 pounds each or the even heavier S-lyte rims at 25.1 pounds each. Perhaps this trend of heavy 17" rims will change with the release of the new style rim from MINI but that is not known exactly when.
Aftermarket white rims in 17" are fairly limited. Tirerack.com would be worth checking but many styles are backordered or out of stock. Centerline RPMs 17x7 are good at about 13 pounds a rim. All of the Centerline 17" rims in the Dominator series are the same weight, just check if you can find any in white that would be in stock.
Centerline RPM 17x7
Centerline Excel 17x7
Source
Or contact Webbmotorsport he sells white Centerline RPM 17x7 or AK Monzas in 16" in white which are light and less expensive.
_________________
Send a PM to minihune Mele Kalikimaka & Hau'oli Makahiki Hou!
Centerline RPM 17x7
Source
_________________
blackie
10-02-2015 07:41 PM
