>>>>Would the 215/45-17 raise my gear ratio? I know the 205/40 lowers it a bit and that's what I was considering.
>>215/45 is slightly taller, 205/40 is severly undersized, 215/40 is the shortest I'd even entertain for race rubber.
>>Alex
Thanks for the info, Alex.
Questions...how much slightly taller is the 215 and which tires do you recommend for race application dry weather only?
>>>>Questions...how much slightly taller is the 215 and which tires do you .recommend for race application dry weather only?
>>Auto X or lapping?
>>Alex
Both preferably. Mostly limited dry weather street, then autoX, then track...in that order.
>>>>I might consider surgery.
>>i have had great results with KD, this is 25.0 inches in diameter, so its a bit taller in diameter. Width was the complication requireing modifcation.
>>Alex
>>What does "surgery" entale???
Severe trimming of the fenderlips and possible reshaping of fender plastic in board of the wheel.
