Brake light stays on red car on jacks appears
I believe that's the brake wear sensor.
Originally Posted by Web
When the Brake Wear Service indicator light illuminates, one of the two Brake Wear Sensors has been triggered. The brake wear sensor is a wire loop that gets worn down against the rotor. Once the wire is worn thru and the circuit is opened, the brake wear indicator light is illuminated.
The MINI has a brake wear sensor in the front left wheel, and the right rear wheel.
The image on the tach should show either the front half or back half of the car. That tells you which sensor has tripped. If you are seeing the entire car on the lift, you need to press the button again until you see which half. (sometimes hard to get this image to show)
The sensors are drivers front and passenger rear. It is recommended that you replace the sensor when you replace your pads etc.
07-16-2020 12:54 PM
Wohnson89
06-10-2020 04:53 AM
