Is there a break-in period for brakes?
Brakes do not have a break in "period" if they're bedded in properly:
http://www.stoptech.com/technical-su...and-procedures
http://www.stoptech.com/technical-su...l-white-papers
on
Brake pads need to be conditioned after they're new and is not a MINI specific thing. Brake pad conditioning involves heating up and a glazing on the brake pads that allows a greater surface for friction between the pad and the rotor. This glazing is actually harder than a non-glazed surface from the brake pad. On lighter brake pads, this can take a few hard (fast) stops in a row, otherwise this glazing will happen occur time. During the break in period, your braking force will not be as great, but will be sufficient.
On rare occasion, I have seen an over glazing which actually made it impossible to completely brake, but this is on small aircraft and while similar, we don't use the electric braking features the MINI has, so I don't believe this would ever be a problem there.
Tinklespout
16
09-06-2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
09-03-2015 03:22 PM
