Any word on Racing Power TH227 Wheels?
Old 11-19-2012 | 12:49 PM
Tab32's Avatar
Tab32
This summer I'm planning of getting some new wheels for the coop. I definitly like these:
Breyton GTS-R Mini
Silver:
Black:
Matte Grey:
OR
Racing Power TH227:
I have a Dark Silver R53 (black roof). I'm not sure which color of Breyton's I'd want. Also, I want to know if I should get the TH227's because they are over $100 less. Pictures would be the best!!!
Thanks,
Teodoro
Old 11-19-2012 | 07:04 PM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
They are available from many sources-
http://www.wheelstudio.com/view-whee...red-pinstripe-
17x7.5 et 40
18x8 et 40
Something to note is at the center of the hub there are multiple drilling for various bolt drillings.
In this example I think it goes far too extreme while the Breytons come in one bolt drilling.
Old 11-19-2012 | 07:07 PM
Tab32's Avatar
Tab32
But they are an okay brand to buy from? I'm not expecting the best quality but I'd like it to last for a few years at least.
Old 11-19-2012 | 07:37 PM
smoke05S's Avatar
smoke05S
If you look closely you can see the Breyton centers are about half the thickness. Also look at the lip and how the center blends in. You can tell the designer spent a lot more time on the Breytons and engineered the weight out of them while the others are just copies. And since the Alloy quality is probably not as good or the construction method they add weight as a safety precaution.
The thing is most people don't look this close. Just get the best ones you can afford.
Old 11-19-2012 | 08:12 PM
minihune's Avatar
minihune
Racing Power is not a main line of wheels, likely gravity cast alloy construction and not very light weight. Finish may scratch easily so be careful and keep the wheels clean to prevent corrosion.
They make about four designs in various finishes and sizes. If you like the design and appearance then give them a try.
I would guess that they would be about the same weight as Stock MINI 17x7 wheels.
Old 11-20-2012 | 01:50 PM
Tab32's Avatar
Tab32
Okay, thanks guys. I think I will give em a try.
Getrieben
09-12-2024 08:03 AM
07-16-2020 01:54 PM
theblackfalcon
10-11-2015 10:49 AM
ki7hy
08-12-2015 08:07 PM
08-07-2015 09:02 AM
Quick Reply: Any word on Racing Power TH227 Wheels?
