Will 05 S wheels fit 08 hardtop
Old 12-06-2012, 04:05 AM
PaulK's Avatar
PaulK
PaulK is offline
Will 2005 S Hardtop OE wheels fit a 2008 hardtop? The tire size on the 2005 are 195/50r16 and on the 2008 they are 175/65r15. I understand the 2008 has an optional size 16" radius.
Old 12-06-2012, 04:08 AM
yetti96's Avatar
yetti96
yetti96 is offline
Yes. All MINIs to date have the same bolt pattern with the exception of the Countryman (R60). The bolt size did change however from a M12 to a M14 but the hole on the OEM wheel should still be big enough to allow fitment on any year car ('02+).
The different in wheel size isn't really important so long as you are not trying to put a 15" wheel on a S model as the brakes are too big for the wheel to fit. With regards to size, the overall diameter is what is more critical when changing wheels and tires. The different between those two you listed is about 1.17% this is negligible because every tire manufacture is slightly different and the size will change that much or more through the wearing of the tread. To me, 3% is enough difference to where you might begin to notice the speedo being slightly different.
Old 12-06-2012, 05:05 AM
PaulK's Avatar
PaulK
PaulK is offline
yetti96,
Thanks for the quick reply. Very informative. I knew the bolt pattern would fit but I wasn't sure about the rest. I thought I might have a problem turning and rubbing. Really appreciate your help.
Old 12-08-2012, 06:43 AM
ricbow's Avatar
ricbow
ricbow is offline
First gen have 12 mm bolt holes, second gen have 14 mm holes . First gen wheels won't fit 2 gen with out mods
Old 12-08-2012, 06:54 AM
oldtruckpainter's Avatar
oldtruckpainter
oldtruckpainter is offline
The stud sizes have changed, that is true. But the bolt holes in the wheels are all the same size. also the taper the coned part of the bolt head fits into is the same. I am running wheels from a 2002 1st gen on my 2010 R56 (2nd gen) with no changes at all. I even can use my stock 14 mm wheel bolts.
Old 12-08-2012, 06:57 AM
oldtruckpainter
Forgot to mention that the 1st gen wheels I'm using are my winter wheels. Not the bridgespokes listed in my signature.
Old 12-08-2012, 10:58 AM
rkw's Avatar
rkw
rkw is offline
It will fit fine. All MINI OEM wheels (all years, both generations) have large lug holes that can fit 14mm diameter lugs.
Old 12-08-2012, 11:40 AM
RedAndBlackMiniS's Avatar
RedAndBlackMiniS
RedAndBlackMiniS is offline
They will fit great with no problems.
reverse01134
01-16-2017 06:37 AM
SosoMINI
11-22-2015 03:17 PM
Mini'mon
08-16-2015 04:15 PM
FrostyFox
08-12-2015 02:33 PM
08-07-2015 08:02 AM
Quick Reply: Will 05 S wheels fit 08 hardtop
