Hey guys just picked up these wheels for a crazy good deal on craigslist. Just wondering if anyone can tell wether I will need to switch to studs or I can use the stock bolts. Thanks!
And if anyone is wondering they are Enkei PF-1 in 17x7 +38
you cant really tell from pics to my knowledge. I JUST had the same issue and the stock bolts on my 2013 were too big to fit (different wheels). So if that's the case for you as well you can either get a stud conversion kit or drill out the lug bolt holes to fit the stock lug bolt size. I went with drilling out and it worked great. If you go this route buy hubcentric rings, very cheap on amazon, around $15. Total cost to drill out will be around $50. Total cost for stud conversion kit will be around $100-$120.
Thanks guys probably going to do the studs since i found a good deal on some through a connection i have. Will be a while till these are on need to get some RS-3's for them and camber plates. Thanks!
