What Size Snow Tires On 15" Rims?
185/65-15 is fine, essentially stock tire diameter even though it is slightly taller than 175/65-15 which is also an acceptible winter tire size.
In addition 195/60-15 is suitable for winter tires and there is a good selection.
See
http://www.tirerack.com/snow/WinterT...=W&search=true
That's a good size. 175/65/15 is theoretically slightly better for snow, but there's
usually not as good a choice in that size. I'm using 195/60/15 because of tire
selection preferences at the time I got them.
I'd probably go for the Michelin X-Ice Xi3 off of this list:
http://www.tirerack.com/tires/TireSe...65&diameter=15
I'm going to need new tires soon and was thinking about Nokian WRG2 size 195/60/15 to replace the 175/65/15. Nokian makes the tire in a 175/65/15 but the tire is rated 84T for load and speed. While the 195/60/15 is rated 92H which is closer (slightly better than the 89H rating of the OEM Conti All Season.
I'm guessing that I would be better off with the tire with higher speed/load rating in a slightly different size as the higher rating usually equates to better handling..cornering, etc. Am I correct?
I may go with one of the better tires at Tire Rack and not Nokian, but either way, it is my understanding that someone should not put a tire with a lower speed/load rating than the OEM tire. In the case of my Justa, that is an 89H.
Is there advantages to one over the other? The 185/65/15 verses the 195/60/15 regarding ride, handling, etc.?
In the past I have been more the type to replace tires with the OEM size, my thinking that the engineers choose that size for a reason and maybe it's the best stay with that size.
185/65-15 is the next best size to OEM, giving a slightly taller sidewall than stock. 195/60-15 is a few mm shorter on the sidewall overall and 60 series sidewall is a little stiffer. 185mm cuts through snow better and gives less rolling resistance than wider tires in the winter/summer.
Handling and comfort for three seasons has more to do with the tire you select than with the actual tire size but tire selection favors 190/60-15.
Kimolaoha
12-05-2020 09:32 PM
col127
08-21-2015 02:11 PM
