conti dw or dws need tire help please
Old 01-13-2013, 06:32 AM
btor's Avatar
btor
btor is offline
Looking for smoother ride then my runflats. Also looking for a tire that tracks straight on the freeways. I will give up a little handling for a smoother ride and would like to keep the 205/45/17. Any other tires out there besides the conti? thanks
Old 01-13-2013, 06:47 AM
Braminator's Avatar
Braminator
Braminator is offline
Since you are in Cali I would go for the DW. Unless you drive in the occasional snow then I would get the DWS like I have on my MINI because I live in PA. These are awesome tire.
Old 01-13-2013, 06:54 AM
btor's Avatar
btor
btor is offline
Thanks. Iam 58 and never driven in snow lol.
Old 01-13-2013, 07:03 AM
Braminator's Avatar
Braminator
Lucky you. Call Alex at Tirerack and he will get you all the info you want on the right tire for your needs.
Old 01-13-2013, 09:00 AM
bmwr606's Avatar
bmwr606
bmwr606 is offline
+1 ... call Alex
Alex Mouroulis | Sales Specialist
__________________________________________________ ________
Tire Rack
7101 Vorden Parkway
South Bend, IN 46628
O: 888 428 8355 ext. 4294
O: 574 287 2345 ext. 4294
F: 574 236 7707
Alex@tirerack.co
Old 01-13-2013, 09:10 AM
GFMINI's Avatar
GFMINI
GFMINI is offline
I have the DWS, its a great all-around tire, low noise... however, would not be first choice if the car was being tracked at all. Definitely a daily driver tire.
Old 01-13-2013, 09:39 AM
btor's Avatar
btor
btor is offline
Was tie tire a lot smoother then the runflats? Not going to track but would like to take a sharp corner once and a while.
Old 01-13-2013, 09:44 AM
GFMINI's Avatar
GFMINI
GFMINI is offline
My only experience with the factory run-flats (all-seasons) was during my test drives on new MINI's while shopping around. I ended up buying a used S and the DWS were basically brand new on the car. I will say that so far I have been driving in 20-50 degree weather, and the tires handle on the pavement as well as the Sumitomo HTR+ tires I had on my 300whp daily driver WRX a few years back. For a small car with stiff sport suspension and 17" wheels, I would put the DWS is the "smooth" ride category, and they so far have held their own handling spirited around town cornering.
Old 01-13-2013, 09:53 AM
Braminator's Avatar
Braminator
Yes by a long shot. They are very quiet and super smmoth compared to the runflats.
Old 01-13-2013, 09:54 AM
Braminator's Avatar
Braminator
Been using them for several years and I am on my second set.
Old 01-13-2013, 10:43 AM
NJ Mini's Avatar
NJ Mini
NJ Mini is offline
+1. Good advice here from Bram.
Old 01-13-2013, 01:55 PM
05r50's Avatar
05r50
05r50 is offline
I had yokahoma s.drives. loved them.
Cali is all summer driving right?
Old 01-13-2013, 06:32 PM
Btwyx's Avatar
Btwyx
Btwyx is offline
The conti tires are good options if you're looking for more comfort. We have DW on one and DWS on the other. The DWS are very quiet and comfortable but not the most grippy tire. The DW are not far behind in comfort, but are considerably higher performance.
We have the DWS because it occasionally gets cold around here, like the last couple of weeks. Conti don't recommend using DW tires in temperatures less than 45F. They're also our touring tire and we may get up to the mountains and encounter snow.
Old 01-13-2013, 07:55 PM
bkosh84's Avatar
bkosh84
bkosh84 is offline
I just bought the DWS's and have put 100 miles so far on them.. VERY nice tire if you are looking for an everyday tire.
Old 01-13-2013, 08:37 PM
planeguy's Avatar
planeguy
planeguy is offline
FWIW....the DWS has a far better tread wear rating than the DW as would be expected for a summer performance tire. If you aren't a hardcore performance guy go with the DWS in my opinion
Old 01-13-2013, 11:11 PM
Btwyx's Avatar
Btwyx
Btwyx is offline
The DWS tires come with a 50,000 mile warranty, but the way we drive it looks like we'll only get 27,000 out of them. Then we'll get to try to collect on the warranty.
On the other hand the DW tires look like they'll last 18,000 miles.
Old 01-14-2013, 04:12 AM
Braminator's Avatar
Braminator
This is an all season, so in Cali it is not needed. He can find a different summer tire with a higher treadware rating. This is why I told him to call Alex and let a true tire expert help him chose the right tire. Just my opinion.
Old 01-14-2013, 06:04 AM
jcauseyfd's Avatar
jcauseyfd
jcauseyfd is offline
fwiw, I got 31,000 out of the DW, but they were worn down to about slick. I'm currently at 30,000 on the DWS and at about 5/32nds on the tread.
Old 01-22-2013, 09:40 AM
stxmini's Avatar
stxmini
stxmini is offline
hello! i have had both. dws very smooth, quiet and handles quite well. if push hard they will chunk off a bit on the shoulders. dw a little louder, more grip and wears very well when pushed.
the dws came with the vehicle when i purchased and will be changing out soon. i am in texas do not need an all season. that is what my truck is for!
Old 01-23-2013, 06:21 AM
btor's Avatar
btor
btor is offline
Called Alex and i'am going with the DW unless i change my mind the last minute, thanks all
Old 01-30-2013, 07:10 PM
davepb326's Avatar
davepb326
davepb326 is offline
so i bought some conti dws for my 09 R57... does anyone notice any vibration, or shake with any tire?? this happens around 63 - 70mph... and not constant... the tire installer says that the mini just does that... thoughts? i dont remember with the old tires...
thanks
Old 01-30-2013, 07:23 PM
Braminator's Avatar
Braminator
thanks
That is total BS. Take it back and have them rebalance them and ask they do it in front of you.
bkosh84's Avatar
bkosh84
bkosh84 is offline
hm.. I have the DWS's on my car (pretty much brand new, a tick under 1k on them so far) and I haven't had that problem. I'd have them check it again? Did you get an alignment done when they installed the new tires? That could be the issue.
Old 01-30-2013, 07:29 PM
Braminator's Avatar
Braminator
I am on my second set and NEVER had that problem.
Old 01-30-2013, 07:35 PM
davepb326's Avatar
davepb326
Thanks for replying guys... yes, they put the tires on with an alignment. I am taking it back to have them redo... thought i would give them a try as they were one of the only "national" companies to replace a RF tire with a nonrf.
Quick Reply: conti dw or dws need tire help please
