What's Lifespan of Pirelli Eufori@'s?
I'm replacing my rims/tires are soon as my stock runflats' lifespan is over. I have about 17000 miles on them, and they don't seem to want to die anytime soon.
I took them to a local shop and they told me the tread still looks good...
I'm baffled because I've read on NAM that people have replaced them after 13000 miles !
20-25 can be had if well rotated, and not driven agressivley
Alex
Alex
I'm on 32k and have what looks like less than half of tread left, except for one front tire that is wearing on the outside, possibly due to some alignment issues....I've rotated them front to back once in their lifetime at 13k. They don't wanna die! I bet they can last with one more rotation to 36-40k. then I'll get some 'real' tires.
Why not think about getting a nice performance tire (non-runflat) and wheel package from the Tire Rack. They come mounted and balanced with air in them ready to go on the car. Throw a can of fix-a-flat in the boot and motor on. You can always keep the run-flats around for long trips. :smile:
>>I am at 12,500 and my tread looks good. I need to rotate them however. Any suggestions on that? What type of interval should I be looking at for rotation. Eventhough the tires are heavy I like the runflats.... gives me piece of mind....
I rotated mine at around 7500 miles or so. I, like everyone else, would like for these tires to wear faster so that I can justify replacing them. I think if you rotate them every 12,500, you will probably get at least 30K if yo're not real hard on them. I rotate my own - very easy with a 3 1/2 ton hydraulic jack and four (or just 2) jackstands.
on
I got about 13K out of the fronts before they needed a change. I probably could have gotten another 3 to 5K of "normal" driving out of them, but they started loosing their grip. They'd probably last longer if I wasn't such a fun loving driver.
_________________
03 B/W S model; Madness intake; Cibie 45 lamps; Magnaflow exhaust; H&R springs; Helix swaybar
_________________
>>Thanks for the info. I guess I need to get them rotated today then. How do you measure the tread... Everyone is saying 50% and all... how are you coming up with that number? I guess I should start looking into another tire... I have always been a fan of dunlops... Any suggestions?
Check out TireRack. Tell it you're shopping for tires for a Cooper and it will make a couple of recommendations, a few of which are Dunlops.
hexproject
09-07-2015 08:23 PM
09-03-2015 03:01 PM
