Brake Help Please!!!!
My right front wheel is already off, and nothing about the caliper looks like any of the videos I've watched on this site, or the pictures in the Performance Mini book! There are no rubber caps, no hex bolts, just four bolts and none of them want to budge. I have a 2010 Clubman S, already bought the rotors and green pads, and now it looks like I'll just have to put the wheel back on and hope the garage will put on the parts I bought. Any ideas? Any suggestions welcome. Thanks, dennis lowe
![Confused](https://www.northamericanmotoring.com/forums/images/smilies/confused.gif)
Vendor
The 2010 calipers are easier than the earlier ones your talking about. Just look at the bolts and you'll see how it comes off, or look at the bentley manual it is the best, that performance book is a joke.
You need to grip hex head on the inner bolt, then turn the outer bolt. The inner hex head is a bit thin so my wrench doesn't fit on it. I've ended up using some vice grips to hold it.
Also make sure you're turning the wrench the right way. I got confused because the bolt is pointing away from me. I managed to tighten it so much it sheered off.
Tinklespout
16
09-06-2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
09-03-2015 03:22 PM
