Runflat Sensor and EMT Tires
To reiterate what DID said, it doesn't matter what kind/brand/size tires you put on. The sensors will still work. All they are doing is making sure each wheel turns at the same rate. A tire with less air will rotate quicker than a tire with more air. If it detects one tire is rotating quicker than another, you'll get the EML warning.
No, you don't need new sensors. Just throw on some new tires, reset the EML (button under e-brake) and go.
R
R
Kimolaoha
12-05-2020 09:32 PM
