Wheels and tyres for Countryman JCW?
If you go to tirerack.com and enter the CM JCW (MCS) into the upgrade garage and select wheels then you get-
Possible wheel sizes with tire size
16x7" or 7.5" et 40-42mm 205/60-16
17x7.5" or 8" et 45mm 205/55-17
18x7.5" or 8" et 45mm 225/45-18
19x8" or 8.5" et 40-45mm to 45mm 225/40-19
20x8" or 8.5" et 42-48 to 45mm 225/35-20
17" OEM and most aftermarket wheels will fit, and will be lighter than 18 or 19 anchors. Stock 17" tire size is 205/45-17, and there is a decent number of top-quality tires available in that size.
a
i just looked in realoem.com
the front disc on the JCW CMS All4 is listed as 307mm diameter, the same as my 03/2012 build CMS All4
i have mini OEM Euro 16" alloy wheels for my winter tires ... the fit is close, but clears
photo with 205/70R16 tires on Mini OEM Euro Alloy 16x6.5 wheels
scott
scott
scott
scott
a
what i was not sure of was the rotor size
if the calipers are the same and the rotors are the same size then the 16" wheels should fit
scott
08-12-2015 01:24 PM
PelicanParts.com
08-04-2015 02:45 PM
