Track Day Wheels, Tires and Pads
#27
Why do you feel wheels without centering rings are better?
The Enkei wheels I have and have had all came with metal rings which were never a problem. I know some wheels come with plastic rings which can melt when over heated on the track which would not be good. Or are there other problems with them?
I am admittedly biased against centering rings as well as spacers, though have run both in the past. Here is why.
When I was younger and budget constrained, I bought a set of new track 17x8.5 wheels for my then E36M3. It was a great deal that required 15mm spacers to fit. Although wheels were perfectly round and brand new, after 3 failed tire balancing attempts by two reputable tire installers, they still shook between 65-80mph. Near-ruined a track weekend. The second guy volunteered to balance them with the spacers attached, and low and behold, finally balanced out the vibration. I marked the wheels and spacers, until the marks wore off over the course of the track/autoX season. That winter I sold the wheels and bought a set with proper offset. Lesson learned.
Then there was the time I got a set of cheapo winter wheels from TireRack that came with *gulp* plastic centering rings. One of them went in crooked and got permanently distorted during initial installation. Had to wait for a replacement to arrive before I could install them on the car. My fault - I didn't do my homework on those wheels. eBay-ed them as soon as I could.
Ever since, I steer towards the simplest possible wheel setup: no spacers (unless unavoidable), and absolutely no centering rings.
YMMV,
a
squawSkiBum
10-02-2015 09:21 AM
Mini'mon
08-16-2015 04:15 PM
ki7hy
08-12-2015 07:07 PM
