EBC Green Stuff brake pads are........
I switched to the Green Stuff pads about a week after mounting my white OZ's, nothing shows brake dust more than white wheels. The difference was dramatic and since than I have found one other item that even improves on Green Stuff not only lowering the amount of brake dust further, but also will prevent the staining that some residue brake dust can leave. The product is from Cragar, that's right, the wheel people. Cragar makes a cleaning fluid that you wipe onto your clean wheels and wipe off, the product is called 'Brake Dust Barrier'. Its an anti-static Treatment that guards against pitting and etching that brake dust can cause from the high temperatures your pads get up to from braking. This stuff really works, check it out:
http://cragarcarcare.com/item/Wheel_Surface_Protection
>>Ive read somewhere that the front or back can not use wear indicators.
>>Anyone care to explain that a little more? thanks. :smile:
>>I have a 03MCS with dusty brakes...
There is a pad wear sensor on one side up front and one side on the rear. The metal base of the stock MINI pads have a little piece cut out in the shape of the pad sensor so the pad sensor can slide and clip in. The EBC pads don't have this little piece cut out, so you can't clip the wear sensor back in -- you just have to tie it off and keep an eye on the pad wear. BTW, Ferrodo pads do have the space for th eclip, so they do work with the MINI sensors.
Thank you for the info. The Ferrodo pads are as minimal dust as the Green pads?
kenchan
Why can't you just cut out a space for the clip on the green stuff pad's.
MGear,
I polished my wheel's with Zaino Brothers polish before putting them on and the dust from OEM pad's just washes off with the Zaino car wash soap. I wash the car and do the wheels last with a soft sponge. Sounds like a nice product, how long does it seem to last?
_________________
B&M S/S, DIY K&N W/Cowl Mod., Rota Slipstream's 16X7.5x45/56.1, 205X50X16 Yoko. ES-100. DIY Oil catch can, DIY exhaust next..
kenchan
MGear,
_________________
I just installed EBC front pads last month on my 04.
The current EBC pads have the sensor notch in the front pads.
We are currently waiting for a new shipment of rear pads with the notch.
Of course these pads have been arriving on the next boat every week for the last month, but EBC is producing rears with the notch, they are just not here yet.
That's all I'm waiting on too. Don't know who carries them for the 04+ MCS though - Anyone?
on
Waxing your wheels with whatever brand wax is the best way to get rid of the brake dust. My prefered is the P21 stuff.
Although there is no way to keep up with the dust of the stock pads, I do not know what kind of horse dung they are made from but it is ridiculous.
Just received my EBC Greens and will install this weekend. Mostly to solve the dust problem, a supposed firmer brake feel will be nice also.
I have a real newb question on these pads.
I noticed the gray area over the actual brake shoes. Is that gray
area the actual kevlar or is that some sort of padding to protect
the face during shipping? It looks fuzzy in the pict so just wondering..
_________________
03MCS IB/B: 123, Aero, R90, SSR Comps, Milltek, Pilo Intake, UNIChip, H-Sport, Alta Swaybar...
_________________
The Ferrodos are pretty good on dust, definitely better than the stock pads. I haven't tried the Green Stuff, so I can't compare them on dust.
BTW, there's no way you could "cut a notch" into the pads for the sensor clip. You'd have to machine cut the pad and the metal backing plate into the precise shape of the sensor clip -- no way it's worth it. Sounds like EBC has addressed this though with its newer version of the pad with the notch for the clip.
I've had the EBC Greens for over 5K miles with no problems. Biggest thing IMHO to avoid rotor warp is to drive a lower speeds for awhile if you have really heated up the pads/rotors. Don't just park it with hot pads as it will warp the rotors regardless of what kind of pads you are using.
