bigger brakes
on
bigger brakes
I was looking at getting better brakes for track use, i think i found the kit i want for the front
http://www.waymotorworks.com/wilwood...1.75-race.html
but i was wondering if anyone has put the front stock brakes on the rear of the car? they are better and bigger so it seams like it would be better to me. Does anyone know if this will work?
on
Putting the front brakes on the rears is going to screw up brake bias, and as mentioned above, you'd probably need a larger master cylinder. The M3 E30 may fit with modification, but if you're thinking of doing that, you'd be better off with a "bigger" BBK in the first place.
on
If you have the R56 brakes that Wilwood kit isn't much improvement. I'd do what tremper suggested, maybe add some cooling (brake ducts), and if that doesn't get you where you want to be then look at a BBK with either larger diameter or larger width rotors. If you're set on Wilwood, they make some good kits, may want to give Todd at TCE a call; Way has some other kits too that are a bigger step up than the kit you're looking at.
I actually run a 12.19 x.81 rotor on a 15" wheel, but it's not a cheap setup. It does bring another set of headaches, mainly with cooling, but it's doable. The 11.75 x 1" rotor for the track setup you linked looks good, and it's well priced if you're married to 15's; if you're willing to go larger diameter, you've got some really nice kits for that, also well priced.
on
Coordinator :: STLMini
on
I use the 11.75 kit with 15" wheels on my R53 track car. With Poly B pad the stopping power is excellent. I did have to add brake ducts because I was cooking the brakes at the track. Now the setup works perfect. A 15" setup is harder to do because everything is so tight, but it has its advantages.
I prefer the benefits of the 15s. I run 225/45/15 r-comps. That width is harder to get on 16s or 17s without rubbing. The smaller diameter improves acceleration, the lighter weight (of the brakes and wheels and tires) help handling, and the lower cost helps the wallet (I go through lots of tires and pads).
Vendor
The 11.75 Wilwood kit can be a great track setup as I ran it for years on my race car. But if you want to move up from that the TSW setup we have with 1.25 wide rotors will last longer and handle more heat.
http://www.waymotorworks.com/tsw-bdm-brake-kit.html
sempaipaul
09-18-2015 03:05 PM
Interior/Exterior Unboxing Video of Sneed4Speed R53 Brake Cooling Kit
Gremothra
09-09-2015 08:42 PM
Tinklespout
16
09-06-2015 11:39 AM
PelicanParts.com
Tires, Wheels & Brakes
09-03-2015 03:22 PM
