Who's got Rotas?
When my MCS gets here, I'm going to swap the v-spokes for Rotas. So I need advice from anyone who has already done this. Do I need to change the OE lug bolts to put the Rotas on? (I've already asked Alex at Tire Rack, thank you Alex) and I have hub centric rings all ready to go.
Thanks!
Shelly
Thanks!
Shelly
On topic- Rotas are great wheels for the money. I know several people who have them and have had no prolblems. Weight to price can't be beat.
Off topic- The first mod to any MINI should be putting wheel studs on. Alex sells them and they are worth twice the price. It is easier to find specific lug nuts vice lug bolts, and much easier to change wheels back and forth.
Chris
Chris
Both sets of mine (also have 15" Circuit 8's) were totally perfect. I know because I inspected every sq cm as I waxed them before mounting tires. Unless the displayed wheels were damaged in shipping they just put out as an example, but as a business if it were mine I wouldn't display a trashed product.
_________________
B&M S/S, DIY K&N W/Cowl Mod., Rota Slipstream's 16X7.5x45/56.1, 205X50X16 Yoko. ES-100. DIY Oil catch can, DIY exhaust next..
_________________
I have polished Circuit 8s so I'm not sure about the slopiness of the paint, mine have a decent clearcoat on them that has not started to flake yet (knock on wood). They're good wheels for the money and I'm still very happy with my purchase. I did not need special lug bolts and did not use hub centric rings (although it's more convenient if you do).
So far then, it looks like I can mount on the OE lug bolts, with a heartly recommendation to swap the bolts for studs, which I'm considering. Thanks for the recommendation Chris. I'll have to lookee see if I can find a how-to on swapping bolts for studs. ( well.... I've never done it before, and I'll be gollywollered if I'm gonna try and figure it out using my truck ) Don't see myself swapping wheels frequently at this point... but the future can bring any number of changes.
Yeah, I decided on Rotas because they have a pretty good price to weight ratio, and a good selection of styles as well. I have seen reference to Rota GT3s being forged, with 16" weighing in at 11 lbs
norm03s - what a wonderful idea! I'm gonna go wax my wheels!
Shelly
Shelly
Wow, that's a mighty kind offer Chris! Uhhhmmm, how do I know what wheel stud size I need? Do they even come in sizes?
I'm figuring it'll take a week or 2 to get everything in one place.
Wheels & rings - got'em
Car - leaves Classic this Sat.
Tires & studs - order from Tire Rack on Monday
Then I need to get the tires mounted and balanced.
Is swapping the lug/studs easier for you to do before or after the new wheels go on the car?
'nother set of 16" v-spokes and nearly new tires coming to the marketplace soon!
Shelly
Shelly
Shelly -- I have polished 16" Rota Slipstreams on my MCS (yes, that's real snow in the background!):
The rubber is 205/50R16 Falken ZE512 (which actually works in the snow).
I got mine from Rspeed in Atlanta and Peter threw in some "Tuner Lugs". The were pretty, chrome dudes so I gave them a try. I found that (even though I initially torqued them to ~80 ft-lbs) the left front wheel would un-torque itself after a few miles.
On examining the freebie lugs, I saw that the diagonal part of the lug (where you develop the friction with the wheel) was a lot shorter than the OEM black lugs. In addition, you could see that some of the chrome plating was flaking off. So I banned the chrome lugs and went back to the OEM black oxide and haven't had a problem.
Since that worked for me I can't offer any recommendations on the after-marked studs.
The 'Centric rings I use are plastic resin, 56.1mm ID, 67mm OD (furnished by Rspeed). They are only about 1/4" thick and fit pretty loosely. I would have preferred thicker metal ones but was unable to find them.
Regards, Tom
Regards, Tom
>>So far then, it looks like I can mount on the OE lug bolts, with a heartly recommendation to swap the bolts for studs, which I'm considering. Thanks for the recommendation Chris. I'll have to lookee see if I can find a how-to on swapping bolts for studs. ( well.... I've never done it before, and I'll be gollywollered if I'm gonna try and figure it out using my truck :smile:
DrFraserCrane
08-30-2015 01:11 PM
