Official F56 Wheel Fitment Thread
Old 04-28-2016, 06:04 AM
randomquickness's Avatar
randomquickness
randomquickness is offline
Originally Posted by MarcoPolo
jumping in on this thread. been reading it since it started but since i wasnt' ready for wheels, i didn't post...now that i'm tracking the car about 6-12 times a year, i need to up my setup (as well as track/summer tires).
i'm torn in the sense that i like aesthetics just as much as tracking her, so my wheel would need to cater to both sides of the spectrum.
my current ideal setup is as follows:
18x8 ET45 on 215/40's. Wheels TBD and Tires are the R-S3's.
seems i shouldn't be concerned with spacers. FWIW, i'm on NM Springs as well.
your tire choice is great but I have to say I prefer 17s for track use. Also, the stock brakes are more than up for track use on smaller tracks. I did experience some fade after a few laps but not too bad. After they wear out I'll probably just upgrade the pads/rotors/fluid and call it a day.
  #677
Old 05-09-2016, 06:54 AM
randomquickness
and another wheel option I'm working on:
https://www.northamericanmotoring.co...rack-guys.html
  #678
Old 05-09-2016, 07:42 AM
VolcanicOrangeF56S's Avatar
VolcanicOrangeF56S
VolcanicOrangeF56S is offline
What is the price range? You can get Team Dynamics in that general weight range and in any offset your heart desires for around 250/wheel. My 18x8's weighed in at 17.8
  #679
Old 05-09-2016, 02:47 PM
randomquickness
so yes the Team Dynamics are nice and I won't knock them one bit. With that being said, it is not IMO an ideal track wheel for this chasis. A 15 lb 17" is still going to be overall lighter (depending on tires) and allows for a broader range of track tires with more sidewall (think rumble strips.) Additionally, you don't necessarily need an 18" wheel to clear a bbk.
  #680
Old 05-09-2016, 03:15 PM
VolcanicOrangeF56S
I don't disagree. I went with 18's because that's what looks appropriate on the platform imo. The 17x8 TD is under 17lbs. I know what weds typically run hence my query re:pricing. If they're 4-500/wheel I don't see a lot of folks dropping double an rpf1 or TD for incremental performance.
  #681
Old 05-09-2016, 03:40 PM
randomquickness
all true, and these might not sell at all. That's why I'm doing an initial run of 10 sets (the minimum to get them made.) And I do like the rpf1 but their 17x7.5 has a pretty conservative offset so folks would likely have to run spacers to clear brakes/run wide tires.
  #682
Old 05-09-2016, 03:42 PM
VolcanicOrangeF56S
I hate how enkei does that �� They make gorgeous low offset faces and then don't sell them on most sizes. My Miata was like that
  #683
Old 05-11-2016, 10:09 AM
VicSkimmr's Avatar
VicSkimmr
VicSkimmr is offline
If y'all are interested in finding wheels you should contact Rajeet at Mastermind NA. He runs a business that imports japanese wheels and refinishes them for people in the USA. He can find damn near anything, can re-drill to whatever bolt pattern you need and is extremely reasonable.
For instance, I had him hunt for a wheel for my F56 and he found a set of gold 17x8 et 45 LM's. He was going to charge me $1,500 for them in refinished condition. Of course virtually everything out of Japan is 5x114.3 so you would either have to him him redrill them or use a stud conversion with wobble nuts to run them on a 5x112 car, but it's still worth talking to him if you want a good set of wheels. I ended up passing because I'm going to focus on finding a good set for my w124 instead of worrying over finding another set for the F56 but he has a really good reputation.
  #684
Old 05-13-2016, 02:25 AM
powermaxi's Avatar
powermaxi
powermaxi is offline
Hi All, my car is 16's F56 S, 6MT, MidnightBlack. And i'm from China.
Dose anyone use this fitment:
wheel:18x7.5j et45, tires:225/40/18,
and with stock suspension, brakes, no spacers, no camber changes
All I want to know is, will this fitment cause any rubbings ? even when the steering locks.
I wanna use the 225 tires because in China the 205/215 18" s tire is hard to buy.
The Michelin, Continental, Goodyear don't offer the 215/40/18 tiers in China.
And 205's tire, I get a little worry about the grip...
So , dose anyone help me with this?
Special thanks!!
  #685
Old 05-13-2016, 04:13 AM
GregoryK's Avatar
GregoryK
GregoryK is offline
Special thanks!!
I'm pretty sure that these will fit without incident. I sure someone else has done this. I run 215 18's and they are fine. Also you could always use small spacers. I run them on mine just to fill the gap between the tire and the wheel arch. Makes the car look super aggressive.
  #686
Old 05-13-2016, 08:19 AM
powermaxi's Avatar
powermaxi
When the wheel's width is fixed for the 7.5J, et = 45, what different between 215/40/18'tire and 225/40/18's ?
If the 215'tire makes enough space for both of the inside and outside, Will the 225's ???
  #687
Old 05-13-2016, 10:37 AM
VolcanicOrangeF56S
225 will be 10mm wider than a 215 (5mm on each side of the wheel). 5mm may not seem like a lot, but with the tight fitment to the hub of the OEM struts, 5mm could cause contact with the strut. (that size seems to be pretty safe. My brother in law is running 225/45/17 on a 17x7.5 +48 and doesn't rub). The only wrinkle in this is if the tire runs big. I.E. my 225/40/18 Bridgestone Potenza Re71-R's cross section closer to a 245. So when you're looking at tires look up reviews and actual widths before you buy!
  #688
Old 05-13-2016, 11:22 PM
powermaxi's Avatar
powermaxi
I want to use the 225/40/18 yokohama AD08R, anyone use this?
  #689
Old 05-14-2016, 06:53 AM
isamin's Avatar
isamin
isamin is offline
I have an R56 but these cars are very similar and use 17/7.5/45 offset wheels mounted with 235(yes) /40/17. MINI is a big brake JCW that is lowered 2" all around. There is NO rubbing. If anyone is interested I have a wheel fitment device that will be FOR SALE at MOT2016. See you there.
ISAMIN
  #690
Old 05-19-2016, 02:32 AM
powermaxi's Avatar
powermaxi
I recently noted that O.Z official provide for the F56 mini's wheel specs is 18X7.5J, ET50.
But they don't mention the recommended tire size ...
If the mod factory says this specs is fit for the car, will they surly prefect and no rubbing at all?
And which tire size can I use? Is the 225 OK?
  #691
Old 05-20-2016, 06:38 AM
randomquickness
yes, 225 is just fine
  #692
Old 05-20-2016, 11:07 AM
MarcoPolo's Avatar
MarcoPolo
MarcoPolo is offline
won't be on for another month...but here we go...
  #693
Old 05-21-2016, 09:49 AM
honderpilot's Avatar
honderpilot
honderpilot is offline
Anyone here have jcw pro Coilovers lowered all the way? I'm looking for clearance/wheel specs that'll fit.
  #694
Old 05-22-2016, 06:51 AM
Andrew725's Avatar
Andrew725
Andrew725 is offline
Enkei 225/45/17 Et45 From Russia
  #695
Old 05-22-2016, 06:56 AM
VolcanicOrangeF56S
That looks awesome!
  #696
Old 05-22-2016, 06:57 AM
VolcanicOrangeF56S
18x8 +40 Team Dynamics ProRace 1.2 with 225/40/18 Re71R
Spyderidol (06-14-2019)
  #697
Old 05-24-2016, 08:28 AM
ECSTuning is online now
Received 2,085 Likes on 1,860 Posts
Nice, are you in the MINI Russia People Club ?
  #698
Old 05-24-2016, 09:57 AM
honderpilot
Originally Posted by ryanschram
lowered it. looks much better now.
What wheels are these?
  #699
Old 05-24-2016, 10:18 AM
honderpilot
Originally Posted by Plautos
OZ Racing Leggera HLT 18x8 et48 with 10mm spacer up front and 10mm in the rear, plus NM springs.
Yokohana SDrive 215/35 no rubbing at all.
The front wheels went off the fender line.
Is that the jcw splitter on your mcs bumper???
  #700
Old 05-28-2016, 09:13 AM
ryanschram's Avatar
ryanschram
ryanschram is offline
enkei TS9
Quick Reply: Official F56 Wheel Fitment Thread
