Official F56 Wheel Fitment Thread
#951
Those look great!
#952
#953
I read the entire thread. Long *** thread for sure.
Just ordered Enkei's VR5 in 18x8 et45
I see that the 205 40 18 will go on no problem and I think the 215 40 18 will as well.
What about the 225 40 18? I found a good deal on these tires and would like to do it if I wont need spacers and if they wont rub.
I drive a stock MCS, no big brakes, not lowered and have no plans to do either.
Just Plain Stock.
I saw this one and only post but I think the set up is different than mine.
https://www.northamericanmotoring.co...ml#post4350068
Just Plain Stock.
#954
Just Plain Stock.
Just Plain Stock.
#955
3SDM 0.66 18x8.5 ET42 with Michelin Pilot Sport 4S in 225/40/18. No spacers and no camber adjustments needed. These bolted straight on with JCW PRO coilovers with very little clearance for the front struts, but no rubbing. I am getting some rubbing on the inner lips of the fender arches on dips and bumps, but the fender is already wearing away so I figure this is a self-correcting problem.
The following 2 users liked this post by shmandrew:
CallMeRacerB (08-26-2018),
Spyderidol (06-14-2019)
#956
I've got 225/40/18 on 18x8.5 ET42. No rubbing on suspension on JCW coilovers, so you should definitely be fine there at stock height. I am getting fender rubbing on hard dips and bumps, but I am lowered. You may be ok there at stock height. The rubbing is on the inner fender arch lip and it looks like it's going to correct itself over time.
I have the same color car. where did you get/make those color matched mirror caps? very cool.
also, how about a front shot on your car, looking down the line (and the grill)
thanks again
#957
Happy to help. Sharing knowledge is what makes this community great and I would have never had the ***** to pull off this setup without some input and advice from another F56 owner running the exact same specs on his setup (different wheels but same specs).
Color matched mirrors were done by my body shop. I brought them a pair of the standard JCW PRO caps and said "hey, make this red orange instead "
I'll try to get some front shots for you in the next few days. Don't have any at the moment. Feel free to PM if you have any more questions on fitment and I'd be happy to help as much as I can.
copajoe (07-01-2018)
#958
Volcanic Orange is the best!
Once I get the rims mounted and balanced I will post some pics and you can show/instruct me how to get from mine to yours! lol
its the fully loaded F56, leather, XL nav, LEDS, back up cam, heads up display, yada yada yada. its already blacked out too, everything but the front grill and side markers so I am already on the path. Getting the black painted (as they call it) VR5 from Enkei. The should look good when installed with the 225 beef!
#959
excellent. I will take you up on that!
Definitely share pics when you get the wheels on. It's gonna look hot!
#960
I just used 66.6 hub rings. Close enough to do the job IMO. 0.1mm is an extremely small difference.
#961
3SDM 0.66 18x8.5 ET42 with Michelin Pilot Sport 4S in 224/40/18. No spacers and no camber adjustments needed. These bolted straight on with JCW PRO coilovers with very little clearance for the front struts, but no rubbing. I am getting some rubbing on the inner lips of the fender arches on dips and bumps, but the fender is already wearing away so I figure this is a self-correcting problem.
#962
#963
Advanti HY Hybris 18x8 et45 with 225/40/18 perfect fit.
I am new to the Mini scene but not to the BMW one. I have a 2015 MCS, it's JB4 w/FF map 2 tuned with Miltek down pipe and 40% E85 fuel. It's got and AFE intake and I will be fitting the Remiss exhaust asap. I just installed these wheels today. No drop yet but I'm trying to decide coils or springs . I have springs alone on my X5 and it feels great. But I had coils on M3 which was great too. Please chime in and let me know what works best with my setup. Here's some photos of the wheels.
Unboxing
Before
Suspnsion not settled yet
After a nice drive all settled.
Unboxing
Before
ECSTuning (07-27-2018)
#964
I am new to the Mini scene but not to the BMW one. I have a 2015 MCS, it's JB4 w/FF map 2 tuned with Miltek down pipe and 40% E85 fuel. It's got and AFE intake and I will be fitting the Remiss exhaust asap. I just installed these wheels today. No drop yet but I'm trying to decide coils or springs . I have springs alone on my X5 and it feels great. But I had coils on M3 which was great too. Please chime in and let me know what works best with my setup. After a nice drive all settled.
#966
The following 2 users liked this post by copajoe:
BeardedR60 (07-26-2019),
#968
#969
Hi guys! I have Mini Cooper F56 S with JCW kit and r506 Cross Spoke wheels, but I'm looking for a new setup for the next season!
My stock specs are: R18 ET54 7J, lowered with Eibach Pro kit.
I want to run with something like R18 et 40-42 and 8-8.5j with 225/40r18 tires, but I'm afraid of rubbing, who rolled on such a setup? Any advises? Thanks!
#970
Ruga (09-13-2018)
#971
Thanks for the answer, yes, i saw it) I have already read all thread) Is it comfotable to use 8.5 wheels, or you think 8j are better? Also I have brembo's, i need some wheels which will fit them)
#972
8.5 inch wheels work, but you've got a pretty small window to work with unless you like a lot of poke. At ET42mm, my 18x8.5s are poking just a little bit up front and are pretty flush in the rear. The clearance to my front coilovers is pretty much non-existent so I don't even know if 18x8.5 ET45mm would fit.
Your best bet and my recommendation is to find the wheel you'd like to run and purchase just one so you can test fit. Make sure you can return it if it does not fit. This may take some trial and error. Good luck
#973
There was a thread on here somewhere about wheel fitment specifically for JCWs since the Brembos are so big. I think it's really going to vary wheel to wheel and is hard to say based strictly on width and offset.
Thanks, yeah, its the best choice) I think 18x8 et42 8j is the best setup)
#974
I went throw this thread 100 times before deciding what size wheels and tires I wanted to get for my 2017 F56 S. At the end of the day I decided to do TSW Valencia's 18x8 et 45 's wrapped in continental extremecontact dws06 225/40zr18 's. I am extremely happy with my decision. I am on completely stock suspension and I have no rubbing issues. The car handles
phenomenally and looks amazing a mean!!!!
#975
Congrats! We carry their line, did not see Valencia on the list for MINI, thanks for confirming the fitment.
